Does this help?
No, no luck. Renamed us.svg to xx.svg (Renamed the old xx.svg first) and changed Easyweather to “Your Country” also changed $flag in wd34settings1.php to xx.svg. Still loads with British flag. Also on numerous occasions when I save Easyweather, it reverts to a different version and my changes are gone.
John
Have you searched for the answer? I think you are supposed to rename us.svg to uk.svg . . .
All you have to do is rename us.svg to en.svg
No other changes are required
I just wanted to add my thanks to the author for the hard work. It looks really good! It was very easy to set up, too.
This worked, but is not what was instructed by the reference to a prior thread earlier. Thanks for the suggestion.
John
John, I ran in to the same problem with the flag and couldn’t understand why changing the name to xx wasn’t working. It wasn’t until I tried my site in a different browser that I realized it was a local caching issue.
-Chris
Sent from my Pixel 3 XL using Tapatalk
Well, I thought it was working!! As soon as I open Easyweather and save close it reverts back to UK flag. It is like it is opening an old file. If you have to clear the cache to go into settings that just isn’t going to work.
John
Your site is showing the US flag
Cleared my cache and it is showing correctly now.
John
The updated scripts .zip download includes:
[b]w34_frames.php[/b] Changed Ventusky forecast (not allowed to use in an iframe) to windy.com embedded
The Ventusky forecast is still working here in January (as left, /pws/, see Menu) and July (/pwsnew/) releases?
yes , they do not allow it but for now they do not enforce it.
FAQ [quote]May I insert the Ventusky application into an iframe created by me on my website?
This way of inserting our website isn
It seems that neither %maxavgspdt% - “maximum average wind speed time” - nor clientraw [135] - “max gust today time” - is reset at midnight.
I refreshed the WD34 page (Ctrl-F5) at 0002 this morning and got noreset.png, attached. At 0014 everything was OK again, see reset.png. (Clientraw is uploaded every 20 secs, and customtextout every minute, so that should not be a problem.)
You speak about a version 07 but the download file name is 06-27!
Normal?
When I received the 2017 scripts last year, I planned 4 versions for this year. This is the July version, which was ready for download June 27.
There is a update zip you have to download also.
Thank’s for your quick answer. It will be useful to have the list off the release and the version of the zip file. Perhaps also the current version in the footer?
The template name: WD34, the release 1907 (July 2019) is in the footer.
Post your
You should not to have to clear the cache (with FTP).
All is needed is a force reload which “refreshes the cache for the current site only” => “ctrl” F5
=> Refresh your cache - When hitting F5 just isn't enough!
So the old xx.png will be reloaded with a new version, if it is changed or not.
Sometimes this is also necessary when a css file is changed.
OK. I think I have a solution.
There is also a 7day summary for uploading-users with an API-key.
That summary is updated every 30 minutes or so, not 1 / day as with the daily summary.
So I adapted the load data scripts
And in the live data the current temp/wind a.s.o. are checked with the available high-lows also.
I attach the two scripts, make a copy of the current ones before replacing with these test-scripts,
P.S. Ken True (Saratoga) found a solution for the data without decimals, it seems to work and is tested for a few days at
The current data with decimals will really make a nice dashboard, I think
wu_daily.zip (13.6 KB)
Now it looks right with me. Thank you very much.
Unfortunately, I have discovered a new mystification. When I want to see values for this month, the scale stops at July 25.
