Correction:
I tried again my wifeâs computer and her computer showed the page correctly.
Now Iâve cleaned up my Chrome and it looks like the max and min are currently showing up correctly. I will watch it during the day.
The problem with pop-ups is no longer there either.
Unfortunately, still an inaccuracy.
Early in the afternoon, the temperature crept up above 20 degrees for a short while.
It can be properly seen on the Temp today pop-up.
But maximum temperature is still displayed as 19 degrees.
Ye, I know.
I am on vacation until July 28. immediately thereafter I will have a new version for todays and yesterdays data.
Maybe even earlier, but one has to wait for a hours to check if a solution works also later in the day.
I wanted to ask something. I ordered UV and solar radiation sensors for my Davis VP2. Once arrived I will activate in the template the relative section that will indicate the data coming from these two sensors. In the pemplate Demo the UV / Solar box is active but not by trend graphs. I wanted to know if they will ever be implemented and especially if the indication of the ET index will ever be implemented.
Itâs just my curiosity
I have installed your new template version at https://www.weatherinharrogate.co.uk/pwsWDjuly/ and I have changed all the settings except the path to the clientraw.txt data and the webcam picture. If I try putting these paths in I get a Wordfence Error on my screen with error 403. The previous version is installed at https://www.weatherinharrogate.co.uk/pwsWD/ and this works fine. I can change the path in the easyweather setup up file and it is okay in this version. I can send you the password.
-------------------------This is what appears on the screen
403 Forbidden
A potentially unsafe operation has been detected in your request to this site.
Generated by Wordfence at Mon, 15 Jul 2019 15:24:00 GMT.
Your computerâs time: Mon, 15 Jul 2019 15:23:59 GMT.
April version: https://www.weatherinharrogate.co.uk/pwsWD/w34_module_test.php => click left bottom box with âŚ/weatherdisplay/clientraw.txt
=> 403 Forbidden A potentially unsafe operation has been detected in your request to this site. a.s.o.
So both versions complain, but the April version works although there is a complaint.
I inserted in the html the link to the webcam in the July version => OK
So these errors seem not to block the working. The Wordfence does not like linking to another folder backwards, i think. But it still seems to work.
Could you please add the correct links to your settings? So that i can see if it works?
The data for the graphs com from WU and there is only UV data available, no solar.
As it is still not clear if and how WU will continue access to out own data, I will start after my vacation with new graphs based on the new WU-api.
The 7 day data contains both UV and solar. There can probably be a meaningful UV-solar graph added.
I do not understand what what you mean with ET-index.
There is a calculated ET-value (Evapotranspiration) when there is a Davis console but not all weather-programs deliver that.
There are requests for soil-moist sensors and extra temp-hum sensors, so the ET-value can be added to the list of new weather-values.
Be aware that the WU-data does not deliver any ET-values as I am aware of.
Use for all these and further âwishesâ the special âwishesâ-topic => http://discourse.weather-watch.com.new#new
There we discuss the needed enhancements to the template for the next version.
I have put the full html address in for the clientraw.txt file/webcam pic and that works fine, as you say for some reason wordfence allows the old version to work, but not the new July version. I will just leave the full address for the time being. Many thanks for the prompt reply. I guess other people may come across the same issue if they are looking to another folder backwards.
Hallo Wim,
wanneer ik de template test krijg ik de volgende meldingen.
Warning: file_get_contents(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /home/meteosle/public_html/pwsWD/w34_livedata.php on line 576
Warning: Cannot modify header information - headers already sent by (output started at /home/meteosle/public_html/pwsWD/w34_livedata.php:576) in /home/meteosle/public_html/pwsWD/w34_index2.php on line 88
the solar radiation data are availabe from WU, you already fetch it with your actual data set.
I added the solar radiation graph to w34_graph by
$grphs[âsolar|dayâ] = â|â. â|0|â.lang(âSolarradiationâ).â|â. â|0|â.lang(âSolarradiationâ).â|â.$temperatureconv.â|â.âW/m2â. â|13|-1|HH:mm|12|||â;
Has anyone used the weewx realtime.txt setup? Iâve tried using it and for some reason my temp drops to 0 degrees at times and my barometer stays at 0.00. Website address is https://klephtic-math.000webhostapp.com/
Problem with max wind|gust block just after midnight when max gust not displayed at all. Checked live data and max gust was 0, so Iâm guessing itâs down to the conditional in line 79 of wind_c_small.php
if ($weather['wind_gust_speed_max'] <> 'n/a'
which says, basically, if max gust is n/a (or 0) then donât show anything. (But I havenât worked out why max wind time was still showing 14.20.)
Wim, I might have fixed it. Iâm using the Cumulus CRT to creat the realtime.txt I changed the setting from loop to archive. I think what was happening is that the Acurite was updating different readings at different intervals which caused the null values. Thanks!!
I have made attempts to change the country flag on my site. USA - I changed the $flag setting in âsetings1.phpâ to âus.svgâ, but any time I save the âeasyweathersetup.phpâ it reverts back to the British flag. There does not seem to be a choice in âeasyweathersetup.phpâ for a US flag. Is there another file that I need to change along with $flag in âsettings1.phpâ?
