First: much thanks for all those beta-testers who spent their free-time to further iron out the errors and inconsistencies of this totally new release
As always the downloads and the documentation can be found here => https://pwsdashboard.com/
Warning : In this release most scripts and especially the underlying logic has changed. Support for the April release will become more difficult in the coming weeks / months. Please witch a.s.a.p. I am sure you will be pleased by the improvements of the July release although I understand it will cost you hours of your rare free-time.
Improvements you do not want to miss:
No more SQL, just the simple text files remained
Simplified code so you can change the scripts yourself easier.
More adaption in colours, number of blocks, round versus square .
I’ll need you to provide an unused w34_settings1.php file like the April release .
Clicking on ‘Nearby’ in ‘Current Conditions’ brings up EBBR - Brussels. I’ve got KMDT as my nearest METAR station in settings.
https://www.m82a1.us/pwsWD/index.php
Wim,
I have new version here:
https://www.shermanctweather.org/pwsWD/index.php
Everything seems to be working fine.
Tom
Prob a dumb question…but how do you exit the boxes that pop up when using the menu entries? ie. the weather alerts or weatherflow map?
click anywhere outside the pop-up
https://www.m82a1.us/pwsWD/w34_module_test.php
Click on load files
w34_load_files.php (86) METAR not loaded API=ADD YOUR API KEY
The METAR file is not loading because there is no API set for that file
GW400
28 June 2019 06:00
9
Is there a good way of migrating from daily, monthly and yearly .csv files in April version to .txt files generated in ./chartsmydata?
Yes, but it was not tested extensively .
Just rename them from .csv to .txt
They should be the same format.
Could you test if it works by copying the w34_settings1.php from the April release and the starting easyweathersetup.php
That should work.
Otherwise I attach an unaswered w34_settings1.php also.
w34_settings1.php.zip (1.51 KB)
GW400
28 June 2019 06:21
12
Worked (seemingly) perfect.
Thank you!
the WD clientraw label at the bottom of the pages has a strange number after it…does not seem to be the WD version and build?
That’s the version of w34WD, not WD, I think.
Sorry, Wim, I already deleted all the April release files
Many thanks
As @bitsostring already explained I needed a WD34 version-number. Did not want to much numbers and the not often used build can be easily checked in the debug console.
Just realised I still have the .zip you sent for the April version, so I will test that first.
UPDATE: Yes, it works fine, thanks
URL as left but /pwsnew/ instead of /pws/
Sorry, WIM. I missed entering that API.
Click “Home” or browser left arrow (back one page).
Webcam pop-up not working. . . I haven’t had this problem before :?
http://swanston.maui.co.uk/pwsnew/
