There are multiple persons working to find a solution to add missing days probably by using an API-key load.
There will be a solution for this in the coming months, but only if WU decides to keep the .csv downloads operational.
For the October version I am now adding other graphs by using the API: detailed graphs for today & yesterday and high-low graphs for last 7 days, last 31 days a.s.o
[quote author=weather-at link=topic=68132.msg548804#msg548804 date=1564563676]
Hello Wim,
I tried your new scripts (WU data) but decimal for temperature is not working for
I’ve installed a webcam and downloaded the zip file and updated the website.
No longer is there a blank screen on the pop up when viewing with MS Edge or Chrome on a Windows PC but there’s still a blank page when using Safari or Chrome on an iPad or iPhone (and it’s not a cache issue if that’s relevant). http://www.collapit.org.uk/pwsWD/
Your site does not display the webcam image most of the times as the image from http://collapit.ddns.net:8081/ never fully arrives, the browser is still trying to load data, even if the data is “almost” there.
I opened http://collapit.ddns.net:8081/ on the iPad it never shows the received data.
On a mac it shows the image but still tries to fetch more data.
I think you should change is in such a way that the camera should not be accessed for the image.
The image should be uploaded every so many minutes and then accessed from the website as a normal image.
(But I haven’t worked out why max wind time was still showing 14.20.)
All OK this morning
Around midnight there is a lot of housekeeping for a weather-program: min/max today, yesterday values, optional min/max month/year a.s.o.
So it is often that until some time ( 1/2 hour) not all values are initialized. The times will be correct after the first non-zero measurements.
Sorry, it’s not right when I really look at it: the depth is always reported and shown in km, so the depth units have to stay in km whether the distance is shown in miles or km.
Seems to work OK, at least the gust does not disappear altogether. Screenshot wind.png taken at 0001.
I guessed as much when I said
It seems that neither %maxavgspdt% - "maximum average wind speed time" - nor clientraw [135] - "max gust today time" - is reset at midnight.
Waited until 0015 - wind15.png - but no change to times. It’s past my bedtime
There are two parts: The top part is, in your case, the current conditions from WeatherDisplay.
The bottom part (with the 30C) is the current “this” hour forecast, from DarkSky.
Add a DarkSky key and that information will also be current,
The bottom part (with the 30C) is the current "this" hour forecast, from DarkSky.
