I noticed this am that daily rain and monthly are updating but monthly is not.
I made the correction on WLL and left for work. When I came home it was raining. WD still showed the value I set this am. Daily and monthly are updating.
I recently updated to Build 366 Feb 25th version. Not sure if that is the issue.
Program event log is empty
Debug info looks normal (noise from all the real ftp counter stuff)
Thoughts?
later update: now it seems fine. very odd.
Another update: Its off slightly again - rain has stopped - WLL matches Davis VP2. WD is what is off
Was raining over night. When I got up at 5am, still raining. WLL and Davis VP matched, but WD was under significantly. Now 2.5 hours later, it seems to be caught up.
Also I noticed on WD yesterday rain was 0 when in fact we got .01
Debug info and program event log look good.
Any thoughts? If you want me to send any settings etc I can.
Was out on the deck Sunday and just happen to have checked, looked good. I will take a closer look when I get home; ill remove the cone and look around - good call dan
Curious though why rain was detected yesterday but today it shows 0 in the “yesterday rain” field
Daviswll.txt file shows the correct rain fall - which matches VP console and NOW WD (well WD is .01 off but I think that is from the other day when I updated WLL via web page) -
Eventually it catches up. .However, during the rain event last night, WLL and VP were updating properly. However, WD was not - eventually it did
Btw what is NOT updating on WD - rainfall yesterday. We got an inch of rain yesterday. Yet WD shows yesterday at 0
what I need is a copy of that file when WD is lagging behind
re the yesterday rain, I had fixed that issue when using the console rain total in the windows version
but I will check the code for the Mac version
(its a timing issue)
