Webpage "status" Not all updating [Resolved]
WD is running fine with no issues. All data is up to date
Not sure why I clicked on status. But when I did there are some items that haven’t updated since Nov 3
On the same page it shows WD last restarted Nov 2nd. Trust me I have restarted many times since then.
No big deal. Just wondering if I need to do anything and/or if I should be concerned.
That “Weather-Display FTP NOT Current 622:50:36 > 0:05:15 Sun, 03-Nov-2019 7:26am EST” line suggest that your main and large upload file testtags.php is not uploaded anymore.
Check here http://deputydawgwx.com/testtags.php?sce=view
All data is now only coming from the realtime file (clientraw for WD) but that is missing all kind of historical and high/low values.
When started your main page shows: “Updated: @ 03-Nov-2019 7:25am - next update at 7:00pm - updated 5 sec ago” that is coming from testtags
And a few seconds later that text is replaced with “Updated: @ 11/29/2019 06:21:42 - updated 6 sec ago” from clientraw
Also check http://deputydawgwx.com/wxhighlows.php where the column “this month” shows only dates from Nov 1 or 2
Would this cause the issue
In the advanced internet settings, the file created is green but the file uploaded is red.
Also I seem to have both file #28 and #29 checked
  • update * I found all my before screen shots of when I had to start WD from a virgin copy. I had both #28 and #29 checked
But not sure why the file create is RED
This is the link I used when I set Weatherdisplay to upload testtags.php
It is a separate setting “Create and upload testtags.txt as testtags.php”
Probably there is als a youtube video nowadays.
Much appreciate all your help
I have all those set. Still nothing different
I’m sure I am missing something.
I will go through my before screen shots (again) and see what i’m missing
Hi DeputyDawg here are screen shoots, of some of my setting this may help.
BTrip
I think you have to wait until Brian or another knowledgable person sees this discussion.
The only thing I know from the past is that the sliders on those pages should be set to green and the FTP settings should be correct.
Then it worked. But all this is more then 4 years ago.
Trip, Thanks here is my version of those same screen shots
Differences: custom page where it shows testtags.txt and testtags.php - above that I have HTML (which my before screen shots had) and you have php - also I only have 2 files you have 2 more
In the #28 and #29 files I have mine as file create green but file upload read. Could this be the problem. Btw can you send a screen shot the details of #28
Finally you can see i have the box checked "create and upload test tags.txt as testtags.php
Very odd…
I may post this in the other section of this forum (different people may read that)
Btw I checked on my server, Testtags.php has NOT been updated since Nov 3
Hi DeputyDawg screen shot detail #28. Also attach link to Brians you tube videos http://www.weather-display.com/youtubevideos.php
BTrip
You want both “file create” and “file upload” dots green for #29.
Thanks Trip
I didn’t have the update every minute checked.
Btw do you have that checked for both #28 and #29
OK… I got both files to be green
Lets see how this goes
Everything is fine now
Thanks Tripp
Well I thought this was resolved
I checked earlier and it was back to as it was when i first posted
I went into internet file creations and re-checked the every minute then did a create and upload now - back to green
I came back just now to check and boom same issue and the update every minute is NOT checked. I know I hit save, but i will try again
Any thoughts on how to permanently fix this?
hmmmm not sure what the heck I did, but it looks good now
I let several updates go through and its all still green
Will monitor this for sure
NOPE… back to how it was again
Any thoughts?
you don’t need to have the custom files set to update every minute
that is overkill
every 5 or 10 minutes is all that is needed
the template you are using for your web site pulls the real time data from the clientraw file
Brian… take a look at these screen shots when you can. Custom is set to 15 mins. Clientraw is blank.
Should Clientraw be every minute? I believe I did and saved it, but the save isn’t taking. I could be mistaken
Also the other screen shot (one with green dots) shows the 1 minute not checked
