After several months of runnung without a problem, WDISPLAY is not uploading to my website (northdeeringweather.com). I can’t resolve problem. I have included a copy of my FTP Log in hopes that somebody can help.
xxxxxxx actual message from upload session xxxxxxx
xxx Start Time/date xxx:2:22:19 PM 4/6/2006
Permanent connection selected
Finishedemail agenda
Finished email agenda, and more Internet agenda items to do…
xxx Time/date xxx:2:22:21PM 4/6/2006
Logging onto FTP server…66.36.228.209
Connecting to FTP server
Connected
220 ProFTPD FTP Server ready
USER=xxxx
331 password required for [email protected]
PASSWORD=xxxx
503 Login incorrect
141:530 Login incorrect
CWD \var\www\html
530 Please login with USER and PASS
141: 530 Please login with USER and PASS
Checking for next FTP agenda…
there are 1 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PASV
dISCONNECT: [10053] software caused connection abort
FTP error occured
FTP error, looking for nest agenda item
301: Interrupted
USER=xxxx
PASSWORD=xxxx
[color=red]503 Login incorrect
CWD \var\www\html[/color]
the information needed is there in RED
either you or someone has changed the FTP username or password in WD
or your FTP server is having problems (you need to contact them, its a problem with them, and not WD’s fault)
or try a good ol PC reboot
All login information s absoelutly correct and still can not upload to my web site.
Question: What information goes into WEB FILES/WEB PAGE, WEB FILES SET UP #1, WEATHER STATIOB FILE NAME.
Thanks, George
It can contain whatever you like, but whatever it contains will be the name of the webpage. ie. if it contains “Sitename” then the file uploaded will be named “Sitename.html” and will be the one you need to look for with your browser at your domainname. However, if you still have the problem noted in your original post then you won’t be making it this far as the ftp is failing.
I think it’s unlikely that the ftp login would be “[email protected]” but in any case the problem is either the username/password or there is a problem on the ISP side. Emailing Gary is probably your best shot to get this resolved.
Working on posting FTP Loglist of files uploaded******** actual messages from upload session* Start Time/date:8:40:08 AM 4/16/2006
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do… Time/date:8:40:10 AM 4/16/2006
Connecting to FTP server.
Connected.
220 ProFTPD FTP Server ready.
USER=
331 Password required for [email protected].
PASSWORD=*
530 Login incorrect.
141: 530 Login incorrect.
CWD /var/www/html/
No files to upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Doing abort procedure/program close… list of files uploaded* actual messages from upload session* Start Time/date:8:40:08 AM 4/16/2006
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
No files to upload
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
No files to upload
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
No files to upload
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
No files to upload
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
No files to upload
FTP logoff
QUIT
221 Goodbye.
Disconnected.
Start Time/date:8:47:33 AM 4/16/2006
Finshed email agenda, and more Internet agenda items to do… Time/date:8:47:35 AM 4/16/2006
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
Doing ftp upload
PASV
Disconnected: [10053] Software caused connection abort
FTP error occured
FTP error, looking for next agenda item
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected. Start Time/date:8:47:33 AM 4/16/2006
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
Doing ftp upload
PASV
FTP error occured
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected.
Connected.
USER=****
PASSWORD=****
CWD /var/www/html/
Doing ftp upload
PASV
FTP error occured
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected.
USER=****
PASSWORD=****
PASV
FTP error occured
301: Interrupted
Connected.
You’re still getting login incorrect errors in your FTP logs. This can only be caused by WD passing the wrong username and password to your FTP server. To confirm this, can you try the following:
Open a command prompt (by going to Start menu, selecting “run” and then typing in “cmd” and hitting enter).
At the command line that appears, type the following:
telnet 66.36.228.209 21
and hit enter
You should see text appear that looks something like:
Then type in the word “user” followed by your FTP username and then hit enter. E.g.:
In this test, it’s very important that you type everything in correctly, the first time, including the above username information. You cannot use your backspace or delete keys to correct any miss-entered information in this and following steps! Even though it may look OK on screen, it will send the wrong information to the FTP server.
then type in “pass” followed by what you believe to be your FTP password and hit enter, e.g, if your password is “daffyduck” you would type:
pass daffyduck
You should get a response similar to:
230 Login successful.
If you instead get 530 Login incorrect. you need to contact your hosting company and get them to reset your password for your FTP account (or do it through your hosting control pane) because this means your FTP server is not accepting your login credentials as you believe them to be.
If the above is successful, go back into your FTP setup within WD and re-enter the above username and password as you used above to ensure WD has the current login information.
This completes the test… you can then type “quit” to exit the telnet session and then type “exit” to close the command window.
I did the test and i did receive “530 Login incorrect”. I did enter the the password given to me from my hosting person. I will contact him again. Thanks
