Here is the color combo’s that I think are cool.
http://calgary.westerncawx.net/gauges-ssT.htm
Now to figure out how to get them into my ajax page
I notice that the wind speed, rain rate, wind chill & heat index gauges have max or min markers. I’m surprised that the temperature gauge doesn’t also have this - is there any way to implement it?
Simon
Simon,
Check for minMeasuredValueVisible, and the max of course
Jacco
Thanks for the color changing info Jack.
Here is the direction I am heading (top portion) using iframes. Is there a better way?
http://www.cavecountryweather.com/test.php
Jack,
Check the options in steelseries.js from line 6190, there are even more to choose from.
Jacco
Gaaf. Bedankt. Koud Heh in NL.
I have been looking for these for some time now.
Wow, thanks Jacco. Mark also fixed my issue with the updates randomly stopping. He will incorporate it into a future update but if anybody has the issue I do have the fix.
Jack
Like your front page with the gauges Jack!
I haven’t been able to figure out the scaling of the barometer for inches. The scale goes from 0 to 30. I have played around with the gauges.js with now luck. Any help would be appreciated.
http://www.harpersferry-weather.com/Steelseries/gauges-altT.htm
John
Not looking forward to having to start over with the .js files after an update!
John,
Try these settings;
// define pressure/barometer gauge start values
g_baro.sections = [];
g_baro.areas = [];
g_baro.minValue = 29.2;
g_baro.maxValue = 30.4;
g_baro.value = 29.2;
g_baro.title = LANG.baro_title;
g_baro.lcdDecimals = 2;
g_baro.scaleDecimals = 1;
g_baro.labelNumberFormat = g_labelFormat;
It’s only a couple of lines at this point!
Jack
I made the edits and there was no change to the scale.
John
John,
How do you have this part set up?
cumulus.tempunit = '
[quote author=BfdWx link=topic=54749.msg440035#msg440035 date=1328921304]
John,
John,
What is your gauge site? Maybe it is a cache issue?
Jack,
Gauges are located at:
http://www.harpersferry-weather.com/Steelseries/gauges-ssT.htm
I cleared the cache but no joy.
John
OK, one last thing, go to your customclientrawlocal and check this “pressunit”:“in”, you want it to say “in”.
Jack
That’s what I have. I don’t get it why the scaling is not showing correctly after specifying the min and max values in the gauges.js file.
Now I’m stumped too! Maybe Jacco will chime in soon.
I have been trying to rescale my pressure gauge without luck as well
