I still might need to do more work on this yet
So far the zip update did not work.
Will check tomorrow morning
Normal High
82.0
I need a copy of the
noaastationdata.txt
from the webfiles folder
to debug
Here are the values WD is displaying today
Normal High
82.0
the current latest .zip update of WD works with that file you have posted
make sure you have the latest update
Brian your fix worked perfectly both today and yesterday that both had 2 different years with the same tied max record - THANKS !!!
THE WORCESTER MA CLIMATE NORMALS FOR TODAY
NORMAL RECORD YEAR
MAXIMUM TEMPERATURE (F) 79 95 1936
1911
MINIMUM TEMPERATURE (F) 61 46 1942
https://w2.weather.gov/climate/getclimate.php?pil=CLI&recent=yes&wfo=oax&sid=ORH
Same here for KCON in NH
Appears to work great!
Sorry Brian
It started acting up today, It looks like they added an extra year for all time high temp.
Why do they have to make it so difficult.
Normal High
83.0
noaastationdata.txt (24.1 KB)
Hi Brian
The fix has been working great for a while. Today I have the same issue as windgust where there is a three way tie for the high today. Since three years are tied for the high it
I had not allowed for a 3 way tie 8O
is that the same problem that windgust had?
Brian,
I did attach another file that had a 3 way tie.
You would think they would use the earliest date, But I guess they include all the
dates if the temp was tied for that day. So we could, at some point have 5 dates listed in there.
The three way tie happened again today and a few times earlier. Clearly this is a low priority but wondering if you can modify your fix to accommodate this issue. FYI the low record is never an issue as your code seems to take the first year so it doesn
I need a copy of the raw file
Hi Brian - I’ve attached file noaastationdata.txt.
The direct link is Climate
Thanks a lot !!
noaastationdata.txt (32.7 KB)
Hey Brian - thanks. Do I just run these 2 .exe files and they will update? I didn
just extract the weatherdisplay.exe file to where you have WD installed (exit WD first)
then run that
Thanks. Loaded the fix and will let you know if I see any issue.
As always, thanks for your excellent support
Bonz
I re wrote my code, hopefully it will be OK now
let me know otherwise
