Yes, that was it. Thanks
Hello everyone ,
I followed the above instructions but still had no data in WU reports for 2022.
In my case I continue with the same issue.
Thank you very much
Alexandros
This user found another file
http://discourse.weather-watch.com/p/558261
Check if your similar file is deleted.
If that does not help, sent me the FTP user & password by mail or PM
I will then take a look also.
I will then take a look also.Wim
@ALL I do not like it if someone is making a mess, uses multiple folders, get lost themselves and then ask me to help! and
@meteoarachova The FTP credentials should include access to the real folders.
Those folders where the production .arr and .txt and .php files are.
The settings you mailed me, only give access to a test folder
Hello Now everything is OK ! you can connect at http://www.meteoarachova.com/[color=red]ws_BackUp[/color]/index.php
The files in that folder are untouched since april last year, maybe when you created that backup folder?
They are not used when running PWS_module_test.php => Load files
=> PWS_load_files.php (426) WU-year-CSV___: File not old enough (17935/43200 seconds) http://www.meteoarachova.com/ws/PWS_DailyHistory.php?
Sorry, but please test the credentials before sending them to me.
I need access to two folders in the real âpwsWDâ folder
pwsWHATEVER/chartswudata/
pwsWHATEVER/wudata/
And to the ??/wureports/wuData/ folder, the folder where the real WU scripts seem ?? to find there data from
And to the folder where the scripts are executed
=> IU0394U04 reports. Script startReports.php
=> http://www.meteoarachova.com/ws/PWS_DailyHistory.php
Conclusion:
Probably you yourself is the only person with a good understanding of all those folders and how and when which script reads data and stores it in another folder,
I do not have that knowledge.
Therefor you will have to find the problem yourself.
P.S. I deleted all three messages about the ftp credentials.
Those folders where the production .arr and .txt and .php files are.The settings you mailed me, only give access to a test folder
=> PWS_load_files.php (426) WU-year-CSV___: File not old enough (17935/43200 seconds) http://www.meteoarachova.com/ws/PWS_DailyHistory.php?Sorry, but please test the credentials before sending them to me.
pwsWHATEVER/wudata/And to the ??/wureports/wuData/ folder, the folder where the real WU scripts seem ?? to find there data from
=> http://www.meteoarachova.com/ws/PWS_DailyHistory.phpConclusion:
Probably you yourself is the only person with a good understanding of all those folders and how and when which script reads data and stores it in another folder,I do not have that knowledge.
I can not understand why so many nerves.
If I knew I would not ask!!
I am a beekeeper and I know very well about honey.
So it depends from what angle one sees things.
I honestly have nothing to say.
