Downloaded 5 mins ago…
Might need to do some more testing.
Using Inches for Rain Units.
i did do some testing, but was pushed for time at the time, and at a glance it looked OK
and so thanks to all those who can give me some feedback and fresh eyes
i see the problem,the data is 10* too much
(i need to divide by 10)
use this build 17 .zip update:
http://www.weather-display.com/dowloadfiles/WeatherD.zip
Hi Brian
Installed the latest .zip and its working now.
Henrik
Brian,
Looking good - here is a view of the chart that was automatically uploaded to my server -
Thanks for all your work on this -
Just one question - is it possible to have the header of the chart (the months at the top of the chart) to show on the uploaded version?
My November days got shifted down to the bottom of the month.
Rainfall for 1st was on the 6th, yesterday’s was on the 31st.
I’ll try to post a picture tonight.
Tim, try converting the logfile to data file (112007lg.txt)
Snowman, strangely the headers did not show in the screen shot, so I had to manualy put in some labels (and there was no room at the top)
Thanks for all your work on this -Thanks! thats a great start to the day :D (the wife has given me instructions to shampoo (rug doctor) the carpet today, so I wont be around much today
Rug Doctor=Water= another feature possibility for WD!
I’ve noticed that my raindetail2.gif generation has no rainfall for the entire month of October. The total is at the bottom but is incorrect and the individual days shows all 0’s. What can I do to fix this?
Any help is appreciated.
Mike
the solutions have already been covered on this thread mth
but here it is again
the totals come from the view, rain detail setup
so set the correct total there
the data for each day comes from your data file
to reserect that, go action, convert wd logfiles to data (graph) files, and select 102007lg.txt, and the click on convert
Brian,
That’s the thing…I’ve tried everything mentioned on this thread.
Mike
do you have data in your 102007lg.txt file logfile
I think I see whats going on. Check out the yearlyrain total…how do I correct this? This obviously should be 26.268 down the column unless there is some new rainfall.
See partial here:
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex
01 10 2007 00 16 59.9 64 47.7 30.425 0 0 158 0.000 0.000 0.000 26.268 59.9
01 10 2007 00 17 59.9 64 47.7 30.425 0 0 158 0.000 0.000 0.000 1.034 59.9
01 10 2007 00 18 59.9 64 47.7 30.425 0 0 158 0.000 0.000 0.000 0.041 59.9
01 10 2007 00 19 59.9 64 47.7 30.425 0 0 158 0.000 0.000 0.000 0.002 59.9
01 10 2007 00 20 59.7 64 47.5 30.425 0 0 158 0.000 0.000 0.000 0.000 59.7
01 10 2007 00 21 59.7 64 47.5 30.425 0 0 158 0.000 0.000 0.000 0.000 59.7
01 10 2007 00 22 59.7 64 47.5 30.425 0 0 158 0.000 0.000 0.000 0.000 59.7
01 10 2007 00 23 59.7 64 47.5 30.425 0 0 154 0.000 0.000 0.000 0.000 59.7
01 10 2007 00 24 59.7 64 47.5 30.425 0 0 112 0.000 0.000 0.000 0.000 59.7
no, as stated above, the rain totals come from view, rain detail, and the entries set there
check the logfile alignment, under view, averages/extremes, cehck.correct the data
Logfile alignment seems ok. My graph (102007.inf) file is fine with the totals. When I try to convert 102007.inf to a log file 102007.txt it doesn’t convert over well and creates some bogus information for the rain. Any ideas?
so you have gone from no rain showing for october to rain now showing for october after doing the log to data file convert, but the data is not correct
is that correct?
(just trying to follow what you are saying)
Brian,
I think at this point my problems are beyond the raindetail2.gif. I obviously have logfile and data file problems with October. When I convert 102007lg.txt logfile to data file. The data shows the following at the top for my rain which is totally wrong. For the yearly totals.
When I go the opposite way and convert the data file (.inf) to logfile, the data really gets messed up with the time and the rain totals.
Example for the time (notice the 09 59 where it should be 08 59, it does this throughout the file for every hour for everyday of the month):
01 10 2007 08 57 62.2 76 54.5 30.445 0 0 338 0.000 0.000 0.000 0.000 62.2
01 10 2007 08 58 62.2 76 54.5 30.445 0 0 338 0.000 0.000 0.000 0.000 62.2
01 10 2007 09 59 62.2 76 54.5 30.445 0 0 338 0.000 0.000 0.000 0.000 62.2
01 10 2007 09 00 62.2 76 54.5 30.445 0 0 32 0.000 0.000 0.000 0.000 62.2
01 10 2007 09 01 62.2 76 54.5 30.445 0 0 45 0.000 0.000 0.000 0.000 62.2
Example for the rain (notice no yearly total and rain numbers repeating):
27 10 2007 00 22 59.5 95 58.1 29.849 0 0 180 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 23 59.5 95 58.1 29.849 0 0 225 0.508 0.020 0.020 0.020 59.5
27 10 2007 00 24 59.5 95 58.1 29.860 0 0 338 0.000 0.000 0.001 0.001 59.5
27 10 2007 00 25 59.5 95 58.1 29.861 0 0 338 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 26 59.5 95 58.1 29.861 0 0 338 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 27 59.5 95 58.1 29.861 0 1 321 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 28 59.5 95 58.1 29.861 1 1 270 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 29 59.5 95 58.1 29.861 1 1 262 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 30 59.5 95 58.1 29.857 0 0 202 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 31 59.5 95 58.1 29.849 0 0 202 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 32 59.5 95 58.1 29.849 0 0 260 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 33 59.5 95 58.1 29.849 0 0 270 0.000 0.000 0.000 0.000 59.5
27 10 2007 00 34 59.7 95 58.3 29.849 0 0 302 0.508 0.020 0.020 0.020 59.7
27 10 2007 00 35 59.7 95 58.3 29.849 0 0 315 0.000 0.000 0.001 0.001 59.7
27 10 2007 00 36 59.7 95 58.3 29.859 0 0 352 0.000 0.000 0.000 0.000 59.7
27 10 2007 00 37 59.7 95 58.3 29.861 0 0 0 0.000 0.000 0.000 0.000 59.7
27 10 2007 00 38 59.7 95 58.3 29.861 0 0 42 0.508 0.020 0.020 0.020 59.7
27 10 2007 00 39 59.7 95 58.3 29.851 0 0 90 0.000 0.000 0.001 0.001 59.7
27 10 2007 00 40 59.7 95 58.3 29.861 0 0 60 0.483 0.019 0.019 0.019 59.7
27 10 2007 00 41 59.7 95 58.3 29.850 0 0 338 0.000 0.000 0.001 0.001 59.7
27 10 2007 00 42 59.8 95 58.4 29.849 0 0 332 0.000 0.000 0.000 0.000 59.8
27 10 2007 00 43 59.9 95 58.5 29.849 0 0 202 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 44 59.9 95 58.5 29.849 0 0 209 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 45 59.9 95 58.5 29.849 0 0 270 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 46 59.9 95 58.5 29.849 0 0 268 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 47 59.9 95 58.5 29.849 0 0 208 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 48 59.9 95 58.5 29.849 0 0 202 0.508 0.020 0.020 0.020 59.9
27 10 2007 00 49 59.9 95 58.5 29.849 0 0 259 0.000 0.000 0.001 0.001 59.9
27 10 2007 00 50 59.9 95 58.5 29.849 0 0 270 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 51 59.9 95 58.5 29.849 0 0 225 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 52 59.9 95 58.5 29.849 0 0 202 0.000 0.000 0.000 0.000 59.9
27 10 2007 00 53 59.9 95 58.5 29.849 0 0 161 0.508 0.020 0.020 0.020 59.9
27 10 2007 00 54 59.9 95 58.5 29.849 0 0 135 0.000 0.000 0.001 0.001 59.9
27 10 2007 00 55 59.9 95 58.5 29.849 0 0 150 0.483 0.019 0.019 0.019 59.9
27 10 2007 00 56 59.9 95 58.5 29.849 0 0 292 0.000 0.000 0.001 0.001 59.9
27 10 2007 00 57 59.9 95 58.5 29.849 0 0 271 0.483 0.019 0.019 0.019 59.9
27 10 2007 00 58 59.9 95 58.5 29.849 0 0 180 0.000 0.000 0.001 0.001 59.9
I hope this helps. The strange thing is, when I go to view averages extremes for the month of October, it shows the correct rain totals for the days. I really appreciate any guidance to try and correct the problem.
Mike
dont worry about the year or month rain in the logfile (as stated above) as that is not used
.zip and email me your data file, month102007.inf and the logfile 102007lg.txt
Brian,
I have sent the files to your email. Thanks.
Michael
I noticed that you said you tried converting the data file to log file
you should only ever do that if you dont have a logfile
there is a FAQ on how to set the needed rain totals for each day
try that first
