Didnt want to put this question into wd questions, so i’ve put it here.
Basically, i have a mysql server based on a qnap network drive server.
It has been running lovely for the past month or so, but i made a change to add currentcost1-currentcost6 in the other day, now i am getting errors.
Here are the last few lines of errors as output by the wdmysql program:-
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.614.550.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.714.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.914.650.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.914.550.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.814.550.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.914.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.02.014.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.814.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.714.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.914.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.814.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.814.250.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.02.014.250.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.614.250.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.514.250.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.414.250.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.414.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.414.150.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.314.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.214.350.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.314.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.414.550.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.414.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.01.614.450.661111.200830.0)’ at line 1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘.02.314.450.661111.200830.0)’ at line 1
NOt sure where to start, other than line 1, but that don’t help me much.
Any geniuses about?
Thanks!!
