MYsql help needed [RESOLVED]
I think the problem is the space between the value and the MB
causes the problem
(any custom tag with a space in the output will cause problems with the custom mysql, as the space is seen as a delimter, and so will be the sequence out of order)
I have removed the MB on the end of that custom tag now in a new WD .zip update , ready now
Still the same problem:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘674)’ at line 1
I see something strange in my custommysqlout.txt, it did not happen before:
12/10/11 23:55 14.9 95 22.7 55 14.2 1024.1 3.7 4.3 5.2 25 0.0 1.8 464.8 0.0 0 0.0 0 14.8 18.4 14.9 14.5 14.8 1767 100% 674
There is an extra blank space between the two red values. This is custommysqlin.txt and their respective tags:
%date% %time% %temp% %hum% %indoortemp% %indoorhum% %dew% %baro% %10minavspeedinmetric% %avgspd% %1mingustwind% %dirdeg% %dayrn% %monthrn% %yearrn% %currentrainratehr% %VPsolar% %VPuv% %currentsolarpercent% %windch% %humidexcelsius% %heati% %wetbulb% %feelslikedp% %cloudheightfeet% %vpreception2% %freememory%
Do you think this can be the error cause? Can please check if any of that two tags has an extra blank on their output?
I think its the % associated with %vpreception2% custom tag that is the next problem
use a new .zip update, where that is only added if not used for the custom mysql
Working now, thanks Brian :slight_smile:
And one last question (as I’ve never done it before): how can I add data in the gap that wdmysql has been stopped (about 62 hours)? Do I have to create any kind of file? Does WD read them from log or inf files?
the adding of past data does not work if using a custom mysql
you could have though used the older wdmysql.exe until this was resolved
Ummm… too late then. I see now some tags I use in the custom setup are never stored in WD’s database. I’ll try to do something by hand. Anyway thanks again for your great support from your atipodes.
