Since a long time no probs here but since this morning I have no more alldayvideo :?
Moviemakers starts oke but quit with:
Load library C:\DiskD\Wdisplay\avcodec-54.dll error: Can not find the specified procedure
timeout count 1
timeout count 2
timeout count 3
timeout count 4
timeout count 5
What procedure does it mis and which file is using for that (if so) ?
C:\DiskD\Wdisplay\avcodec-54.dll is present and 12.736 kB from 6/6/2013
Thanks so far !
Text moviemaker:
Direction = C:\DiskD\Wdisplay\alldayvideo
Movie Maker II vers 6.6 13:32:30
Will create last day video
Using new setup routine
looking for files between hours 7 and 22 and minutes 0 and 59
Looking for file C:\DiskD\Wdisplay\webcam\0700jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\0700jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\0701jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\0702jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\0703jpgwebcam.jpg
etc etc
Looking for file C:\DiskD\Wdisplay\webcam\2246jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2247jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2248jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2248jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2249jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2249jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2250jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2250jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2251jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2252jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2253jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2253jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2254jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2254jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2255jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2255jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2256jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2257jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2258jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2258jpgwebcam.jpg File date =07/19/13 now date 07/20/13
Looking for file C:\DiskD\Wdisplay\webcam\2259jpgwebcam.jpg
C:\DiskD\Wdisplay\webcam\2259jpgwebcam.jpg File date =07/19/13 now date 07/20/13
output directory for videos is C:\DiskD\Wdisplay\alldayvideo Load library C:\DiskD\Wdisplay\avcodec-54.dll error: Can not find the specified procedure
timeout count 1
timeout count 2
timeout count 3
timeout count 4
timeout count 5
:oops: sorry little late no email notice of reply (and bussy with my error )
I didupdate latest vers B69, same rror
Back to moviemaker april 2013 works oke
but now I have an memory error ONLY AT NIGHT (from 0.00 till 6.00)
Wdwebcamcapture stops making jpg files til 0600 see att 1
movie maker doesn’t stop between 0.00 - 6.00 h results in att 2 and 3
(translation: the instruction refers to memory read operation failed)
I disabled wdwebcamcapture ‘reset daily’ setting waiting now
No errors futher more in log files
no viruses / trojans
how to stop moviemaker at night ? or
how to keep wdwebcamcapture live at night ?
btw: what ever I do it has no effect (setting start/end time moviemaker)
any cache active (cleared memory in help/free memory now but auto at night always is it ?)
with moviemaker last version can’t find procedure
Looking for file C:\DiskD\Wdisplay\webcam\2457jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2458jpgwebcam.jpg
Looking for file C:\DiskD\Wdisplay\webcam\2459jpgwebcam.jpg
output directory for videos is C:\DiskD\Wdisplay\alldayvideo Load library C:\DiskD\Wdisplay\avcodec-54.dll error: Kan opgegeven procedure niet vinden
timeout count 1
FrameInput [Canvas] read frame #562 #1844.3: [frameinput @ 00C9DEC0]Failed to read frame (Canvas) or read interrupt #1844.6: video:1629kB audio:0kB global headers:0kB muxing overhead 1,50%
this is moviemaker 5.5 oke, but I now moviemaker will give mentioned errors from midnight till 05.00 h
Maybe important: I still use Win2000 dedicated for my WD
it always runs as a charme
Could it be the avcodec-54.dll and avcodec-52.dll only run from WinXP ?
and what does error: Kan opgegeven procedure niet vinden translate too?
sorry it means Can not find the specified procedure
Also in Time Stamped Files Setup checked : Create the file at night time too now (did not know unchecked it !)
Now moviemaker II 5.5 creates the movie anyway by day
(but still those errors at night) as mentioned before
see att 1 and 2
Looking for file C:\DiskD\Wdisplay\webcam\2456jpgwebcam.jpg
output directory for videos is C:\DiskD\Wdisplay\alldayvideo\
timeout count 1
timeout count 2
and see also att1
for me MM 5.5 is the latest working vers in Win 2000 makes movies at day no probs
(still have errors at night : wdwebcam stops making pictures; all pictures from 22.00 h till 05.00 h are the same one as 22.00 h see att2
it stops at 22.00 h (set start at 01.00 and stop at 24.00 let me override the times) see att3
so what’s the point:
or
stop moviemaker trying making movies at night
or
let wdwebcam go on making pictures at night
the problems all stem from the fact you are not using the latest version of moviemaker (which looks like the updated dll files do not work with windows 2000) and you are not using the new all day video setup
I dont think there are many people using windows 2000 any more
so my only suggestion is to stick with a version of WD that works for you OK
