I thought it would be nice to allow you to create your own map for various purposes.
This plugin allows you to easily define map parameters. First you choose the map type (terrain, road, satellite etc.), then map height, then you define unlimited number of points by GPS and you give them a title and description. Finally you select if you want to show your points on the map as markers, a connected path or both and you can even choose path color, width, opacity etc.
Finally, below the actual map will also be an interactive table, where clicking the point will take you to the actual position of that point and open the description of it.
Tip: the map allows you to select heading for it depending on which purpose you want to use it for. In the menu, if you use the default plugin syntax:
#plugin(myMap) - if you want to do this you need to update menu.php
it will be called just “map”. If you want to use your own title, you have to use the link to that plugin in the menu as if it was an external link, i.e. specify the URL of it (http://… plugins/myMap/index.php). See the wiki section about menu for this.
added support for Swedish (thanks to Thomas for the translation)
Plugin Update - NetAtmo 2.0
I made some optimizations in the plugin and transferred the original settings, which was done directly in the code, to the GUI of the Meteotemplate control panel. The plugin is now set up via the Plugins Setup page in your Meteotemplate control panel
this new block is for NetAtmo users. You need the NetAtmo plugin installed (version 2.0+) and it will show the current CO2 and noise level from your main unit.
this new plugin is all about hurricanes. First you select a basin (Atlantic or Eastern Pacific), then you select a year (1995-present) and finally a list of hurricanes for that basin and year are loaded. After you select the one you are interested in, its path will be displayed on a map below, where you can also click the individual path points to show more info. In addition, there is a direct link to a PDF with detailed description of that particular hurricane.
For hurricanes between 1995 and 2010, only the PDF is available, maps are available for hurricanes after and including 2010.
No need to setup anything, just make sure you update your menu file so that a link can be added to your menu.
