Lightning Detector
For a few days I have had more or less correct information and my (Lightning Detector)
Function less better.
Herewith lines.
Loaded all time records
Connecting com port
Com port connected OK
**Searching for Weather station sensors
Switch (windspeed or rain or lightening counter) i-button found ID E4000000065B2C1D
Lightening detector found and allocated: E4000000065B2C1D
Time period too short
All data downloaded or did not sync correct!
Clearing records
Weather station type number 31
OK
1.1.4.22
Thank you
Serge
France
is that what is showing in the dallas 1 wire setup screen?
Yes
and you say you are having some problems?
can you provide more information on that?
Hello,
What wants to say message:
Switch (windspeed gold rain gold lightening counter) I-short prop found ID E4000000065B2C1D
Doing checking off time zone calculation
Daylight saving in uses
Thank you
Serge
France
what i mean is does it contiune to work even with sometimes error messages?
Not, that does not function.
so you are not getting lightning counts if you use say a bbq lighter next to the arial?
i know that jaxweather uses a 1 wire lightning counter with his VP OK
Serge, have you checked the battery in the lightning detector and that the ROM I/D is correct in the Lightning setup screen?
I do use a 1-wire lightning detector with my VP and it works like a champ…
Has it ever worked?
If it worked when did it stop, did you make any changes?
What is shown in your Dallas 1-wire setup for Lightning Setup
Hello,
The battery is new, ROM I/D is correct in the screen of installation of the lightning
My apparatus to be functioned correctly since more than one year and one week plus nothing.
I specify that I did not make any modification.
Thank you
Serge
France
Water got into detector.
Wire connections went bad.
Detector fried from nearby lightning strike.
For my case Lightning Detector is inside the house, the cables a 22 meters length after control functions normally.
check the com port plug is seated firmly to the pc
After having controlled the port COM and carry out tests on the port USB, nothing does not change.
Hello,
After several tests, my Lightning Detector functions correctly under Windows XP SP2, but does not function at all with Vista (even with the new drivers).
Serge
France
Which detector are you using? 1-wire, boltek, other?
1-wire.
I haven’t seen anyone post using a 1-wire network with Vista yet, I know I haven’t tried.
Are there Vista drivers for the 1-wire network?
Yep, Vista is support on a Beta version: http://www.maxim-ic.com/products/ibutton/software/tmex/index.cfm
Looks like there’s a 32 & 64 bit version though so maybe worth making sure you have the right on installed.
