I have to install the drivers Vista (beta) since the beginning with my version Vista (32 bit), always nothing.
Test carried out on a port com or usb.
Serge
France
Does the 1-wire viewer show the lightning detector?
Does WD show the ROM ID?
Bob
Does the 1-wire viewer show the lightning detector? : YES
Does WD show the ROM ID? : YES
Loaded all time records
Connecting com port
Com port connected OK
**Searching for Weather station sensors
Switch (windspeed or rain or lightening counter) i-button found ID E4000000065B2C1D
Lightening detector found and allocated: E4000000065B2C1D
Time period too short
All data downloaded or did not sync correct!
Clearing records
Weather station type number 31
OK
1.1.2.15 Beta
Doing checking of time zone calculation
Daylight saving in use
sending time to VP console
Serge
France
there is an option to use page 14 for the lightning counts in the 1 wire setup, lightning setup
try that (and then click on save/reset)
After several tests it still does not function.
Serge
France
with using the page 14 option?
try testing the count is increasing with the i button viewer?
with using the page 14 option? : yes
try testing the count is increasing with the i button viewer? : yes
Serge
so the counts show up as increasing with the i button viewer?
No (sorry bad translation).
Serge
so the counts are not increasing even with the i button viewer?
then that means there is some hardware problem
Hello,
I have d
Hello,
After several tests under Windows Vista I confirm for my case a prob
