I notice that the wxcharts page does not load properly on mobile devices. It just loads the poster images but there is no text or description that link to the weather maps themselves. I am wondering if that’s as far as development ever went on the mobile version of that page, and if you plan to ever adapt it further for mobile?
It does work on my tablet. Talking Android here, no iPhone testing.
Hmmmm…I wonder what happens with existing API keys. Don’t see any info on that. It would seem that if you provide them with data they should give you a free key. Maybe they will make a consideration for non commercial use.
Has anyone tried the new API Keys from Weather Underground. I logged in and was able to generate a new key. It is not working so far, but as I remember it took awhile for it to work when I generated the old key.
Regret the new key is never going to work with the old w34 version you have. You need to look here for the latest version, which does not get a forecast from WU either. However, there will soon be a new release that does give the option of a forecast from WU.
The normal release is ready but the documentation needs improvements and there is a lot more work with updating the language files then I expected.
But if you want to switch to the latest version, including the the WeatherUnderground 5 day forecast, download the March 31, beta version and test.
No need to call it “beta” anymore. All functions should work OK.
Download available at http://wd34.weather-template.com/beta.php
The “old” documentation can be found at http://wd34.weather-template.com/
Also when using WeatherUnderground, there is no need to start using the SQL-table.
The pop-up graphs work OK with the WU-data. nothing has changed there.
