Thanks, but I really do like these problems. Thank you for beta-testing the scripts so others can use them also.
I attach a new version of station-cron, I think it will clear the errors from the history file.
If not we have to remove the history.txt and let the script generate a new one.
=== For your information:
The weatherFlow-api only delivers current values for the weather-items. So the highest and lowest values for today and other periods have to come from the history file.
That file is generated and kept correct by the station-cron.
That script can not look back in time, from today the history starts with today’s values.
When the history is correct for a couple of days, we will run a script to load all history values from your WeatherUnderground data.
But first the updating of the history should function correctly.
Looks like it. . . I commented out the conditionals (for direction and average) and got the arrow back. I presume the fact that the arrow is not quite at “12 o’clock” is a rounding artefact?
Could we start a new topic for the new beta version, so July version problems don’t get swamped?
I updated the livedata script and that corrected the temp readings, so they are all imperial now.
Barometer block is not following the “inHG” format even though it says it is.
Also, not sure I understand the Top Wind block. Is that for just the last few minutes or another time frame? I thought it was for the top gust for the day, if so it does not match the weatherflow data. Nor does the history pop-up show the correct data. w34_cron_stationcron is updating every 5 minutes. The main wind block does not have the proper gust either. I also downloaded the newest stationcron.php mentioned in message #341.
Hi Wim
I use WD to trigger the cron jobs so the station cron is done every 10 min the addtoyear cron is done at 23:58 but the empty cron is run at midnight and I do not see a way to change it to 00:10
will the history still work not using WU http://ballaugh.no-ip.biz:2082/pws09/index.php is my test link on my local server
The livedata was updated twice today as I made a typo. That will remove the inHg conversion missing. I attach the script.
Yes it is for the day.
I can not find if the WF-api data for wind is in m/s or in km/h
Could you explain what is wrong and / or to what other data I can compare the api data
John http://scannorthcounty.net/pws09/index.php
The advice to run empty cron 10 minutes in the new day was because some weather-programs upload previous day data after 00:00
As the data AND the crons come from WD, there will not be old data uploaded after 00:00, I think.
The only real problem is with rainfall, that should be set to zero every new day.
The second livedata.php update corrected the barometer problem.
The wind question was - the top wind block and the main wind block show incorrect data. my wind gust was 19.4mph at 11:55, but the blocks show 16mph at 11:51. The history pop-up also shows 16mph at 11:51. Also do not understand how the wind and wind gust can be different values at the same time. See top wind block attached.
The data returned from the WF-server is a snapshot for that moment without min-max values (except for daily rain and lightning).
Weather data such as temperature and pressure do not vary that much in 4 minutes.
The max-wind will be “nearly” reached quit often during a day, as it is averaged to every so many seconds/minutes
Highest wind-gust can be a “problem” that is a "part-of-a-second value, can be a one-time happening with a large difference between the highest gust and the next one.
The snapshot of 11:51 => wind-gust 16.x mph , snapshot 11:56 probably missed the 19.4mph of 11:55
Those measurements we are discussing here are from yesterday and they are removed from the today.txt, therefor we can not check the “log”
Increasing the data retrieval rate to every 1 or 2 minutes does only slightly increase the chance to just catch the “higher” wind-gust-speeds.
There was another problem with the small wind/gust block, I attach an updated version for the livedata script.
Warning: file_get_contents(http://lokaleolucac.altervista.org/wdisplay2/clientraw.txt): f
ailed to open stream: HTTP request failed!
HTTP/1.0 403 Forbidden in /membri/lokaleolucalisa/pws09/w34_listfile.php on line 17
You should have the clientraw on the website you are working on.
You are not allowed on most websites/webhosting companies to do a file_get_contents from another domain.
My weatherFlow hardware is completely separate from my Davis weather software, at any rate the lack of immediate feedback of data is an issue for me with the wf template and the pwsWD template. I will continue to follow and update the the templates as needed. Thanks for your comments on the templates.
I had a question. I\u0027m using this template and uploading data with the wifi logger. Everything works fine … but going through the month of September, the monthly graphs of temperature, wind, rain, etc. Why?
@ALLCould you please always include the URL=link to your website? Or put that link in your forum-profile
With an URL/link I can check what is going on without waisting my time asking for more details.
What is the problem with the graphs?
Are you using WU or your own data for the graphs?
I’m sorry, you are right. I added my website to my profile and I also put the link below.
Yes, I\u0027m using VU for graphics. I think they are working on it because from this morning the annual ones don’t go either, only the daily newspapers
I report a possible bug. In the temperature box, it is the second time that it marks me as minimum zero degrees, but the minimum was 8 degrees. The daily temperature graph is correct and marks the minimum of 8 degrees
The bug seems to be in the https://www.meteocamporamoso.it/pwsWD/demodata/realtime.txt
There is an extra space between the “time highest temp of 8:54” [27] and the “temp low of 8” [28]
As it is a space separated file, all fields after [27] are shifted to the right.
The daily graphs data comes from the temp data itself., not from the temp-low data.
So every packet to WU only contains the real measurements for that moment.
Do you know how I solved ??? I switched from the upload method of the realtime.txt file to the weatherlink 2.0 json API method. I pushed the wifi logger to load the data every 2 minutes. So much ws weatherlink I have a pro account, why not use it ??? For graphic designers we are obliged to use WU or we can use something else. ?? Now that I use this loading method, uploading realtime.txt via ftp to my site, is it useless?
