Hi!
Tested the file and it works just fine. Just let it roll for a while to see if everything is right.
Tanks!
Torjan
Hi!
Tanks!
Torjan
Documentation (mostly current for beta also) at https://pwsdashboard.com/ includes now the beta download link
=> http://pwsdashboard.com/hws_download2019.php?id=betatest
The download will start immediately and the zip can be found in your download folder.
Unzip and upload the pws??/ folder to your webserver.
DO NOT upload the scripts to your current pwsWD/ folder
The index.php will detect that setup need to run first. Password for easy-weather setup is 12345.
Or copy the w34_settings1.php from your current pws folder first
Extra weather-program supported: WeatherFlow (WF) in native mode
The WF users who upload to WU could already use the WU version.
But that WU version is not yet using the all-new history file for missing data.
I am testing that feature with the WF version first.
IMPORTANT
To fill the history table you need to use all three cron-jobs.
Current dashboard version only uses two
w34_cron_stationcron.php => every 5 minutes
w34_cron_addtoyear.php => every day at 23:55
but you need also
w34_cron_empty.php => every day at 00:10
There will small missing / errors in the documentation as I changed a lot of scripts in this third version.
I will finish latest updates this week and then update all documentation.
17:00 CEST . . . removed premature announcement . . .
@Wim
Very nice !
enjoy beta version installed for my second site :
http://seremange-meteolive.franceserv.com/pwsWD/index.php
no particular problems for the template installation
may need to review .css for layout modulesadjusted and updated blocks version
for charts and storage of historical data : if not bother to copy the “chartsmydata” folder to fill the table …?
Best Regards
fto
Can’t seem to get Weather Display Live from the Menu on your page. . . perhaps that’s because w34_frames.php is still pointing to my page
I did ask you to delete all my extras. . .
rest assured it was working to change the links ! Ok it’s done !!
Bien fait! (again)
Wim,
I’m testing the beta at https://www.shermanctweather.org/pws09/index.php
I’m using the WeatherFlow API for data.
I think the API is in C but no conversion.
I hope you understand.
Tom
Why is there no orange wind direction arrow on the compass when the wind is due North?
Is it the conditional “if ($dir <> ‘n/a’ . . .” again?
Same with me, temps in Celsius and barometer is not correct not showing inHg. Also in the advice block it says Dew Point is below freezing and in Celsius, but says it is F
http://scannorthcounty.net/pws09/index.php
John
:oops: re_ my .txt files do not “update” while the corresponding crons tasks are ok ?
The returned data list the [station_units] as F, mph as imperial
The observation data [obs][0] is in metric, without any indication of which units are used for wind where metric should be m/s
This will only show when there is testdata from imperial users. Thanks for testing.
I will change changed the script to not use the units from [‘station_units’]
http://scannorthcounty.net/pws09/w34_module_test.php
=> left bottom selector, choose “./jsondata/weatherflow.txt” and click “list contents”
Large bottom area information shows Filetime (UTC): 2019-09-04T06:24:08+00:00 which an age of 0 hrs 00 min 55 seconds
Click on expand as json
Array
[station_id] => 4918
[station_name] => Village at Old Mill - Westminster, Massachusetts USA
[public_name] => Village at Old Mill - Westminster, Massachusetts USA
[latitude] => 42.55623
[longitude] => -71.88211
[timezone] => America/New_York
[elevation] => 268.31265258789
[is_public] => 1
[status] => Array
( [status_code] => 0
[status_message] => SUCCESS )
[station_units] => Array
( [units_temp] => f
[units_wind] => mph
[units_precip] => in
[units_pressure] => inhg
[units_distance] => mi
[units_direction] => cardinal
[units_other] => imperial )
. . shortened documentation . . .
[obs] => Array [0] => Array (
[timestamp] => 1567578239
[air_temperature] => 17.4
[barometric_pressure] => 983.7
[station_pressure] => 983.7
[sea_level_pressure] => 1015.9
[relative_humidity] => 86
[precip] => 0
[precip_accum_last_1hr] => 0
[precip_accum_local_day] => 0
[precip_accum_local_yesterday] => 0
[precip_accum_local_yesterday_final] => 0
[precip_minutes_local_day] => 0
[precip_minutes_local_yesterday] => 0
[precip_minutes_local_yesterday_final] => 0
[precip_analysis_type_yesterday] => 1
[wind_avg] => 0
[wind_direction] => 0
[wind_gust] => 0
[wind_lull] => 0
[solar_radiation] => 0
[uv] => 0
[brightness] => 0
[lightning_strike_last_epoch] => 1567510487
[lightning_strike_last_distance] => 20
[lightning_strike_count] => 0
[lightning_strike_count_last_3hr] => 0
[feels_like] => 17.4
[heat_index] => 17.4
[wind_chill] => 17.4
[dew_point] => 15
[wet_bulb_temperature] => 15.9
[delta_t] => 1.5
[air_density] => 1.17943 ) ))
w34_livedata.php.zip (9.62 KB)
Also when I run the cron (w34_cron_addtoyear.php) in a browser, a new line is added to the text files .
contents of "./chartsmydata/2019_09.txt", processed as filetype "text file"
Filetime (UTC): 2019-09-04T07:47:34+00:00 which an age of 0 hrs 00 min 12 seconds
date,MAX_outsideTemp,MIN_outsideTemp,MAX_dewpoint,MIN_dewpoint,MAX_raintoday,MAX_windGust,MAX_windSpeed,MAX_radiation,MAX_barometer,MIN_barometer,SUM_lightning,MAX_UV,
2019-09-01 23:55:00,70,56.8,65.3,46.8,0,17,15,n/a,30.08,29.8,n/a,n/a,
2019-09-02 23:55:00,72.1,50.5,49.6,41.9,0,14,12,n/a,30.24,30.08,n/a,n/a,
2019-09-03 23:55:00,73.9,49.3,53.8,44.2,0,16,16.1,n/a,30.27,30.17,n/a,n/a,
2019-09-04 09:42:20,62.3,62.3,55.0,55.0,0.0000,7.0,3.0,165,30.064,30.064,0,0,
2019-09-04 09:47:34,63.2,63.2,55.0,55.0,0.0000,7.0,3.0,390,30.063,30.063,0,1,
How are you running those crons?
Do you have a log-file or a last message?
@Wim
for cron spots i use “cron-job.org” …
the “Last execution” do not send me any errors!
cf. screnn attacment for “Execution history” for (w34_cron_addtoyear.php) ??
thnx
ps_
meanwhile I had launched a script execution :oops:
/_cvt_wu_csv.php
Wim,
I changed the w34_livedata.php file.
It fixed the temps.
On top row min temp says 32, no wind or rain totals.
Baro not inhg
Tom
Yes as there is no min temp available it has 0 in C for temp
no wind or rain totals.Yes a type from me :oops: I attach an update
Baro not inhg
Tom
I ran a test with your latitude/longitude, units, WF-ID on a fresh download , with the correct livedata scripts.
Every 5 minutes I ran w34_cron_stationcron in the browser.
It updated correctly the history file, so the min-max values are updated. See attached screenshot.
At your site, the cron sas it is updating the history, success files loaded + history recalculated but it seems that the file is not . The file is empty, only n/a values
https://www.shermanctweather.org/pws09/w34_listfile.php?file=./chartsmydata/history.txt&type=arr
Probably there is a problem with the permissions/ownership of the ./chartsmydata/history.txt file
I added more debug messages in the script, please unzip and upload the attached script
w34_cron_stationcron.php.zip (2.95 KB)
Wim,
I have downloaded the script.
I now have the crons setup.
I noticed wind max changed from 9 to 2?
On top row no times on wind.
Rain has zero for Sept. but we have had .80 in.
Tom
Could you also update the livedata script from HWS-template (WD34) July version available - #336 by pwsdashboard - PWS Dashboard 2012 - Weather-Watch Forum
I tested your site again and the history file is not updated with new contents.
I ran out of ideas for now, I must rethink and try to add extra debug messages.
Thanks for testing so far,
Wim,
I had downloaded that w34_livedata.php file which did correct the temps. I will download it again.
I also changed permissions on the chartsmydata file to 775.
Thank you for all your work.
Tom
