But I recently saw a nice graphic with the actual sun position and lines of min. and max. sun height (see attached file).
Does anyone have a simular graph or script or know where to download this?
Thanks for the info. But do they allow do link it on your own page?
I think it is a script, too. It will calculate the position and shows it as a graph. Perhaps someone is able to code this …
Found that, e.g.: 3dspace.de is available for purchase - Sedo.com
I wonder…
Can someone add the moon to it ?
I found a lot of info on how to do the calculations, even have a scource in C++, but I can’t translate it to PHP
Thanks for sharing it. When I’m home I will try to put it on my site.
By the way, woudln’t it be interesting to have it as an ofc? That when you point at the sun you got some data like Time or something else. I would program that but I can’t.
I found a lot of info on how to do the calculations, even have a scource in C++, but I can't translate it to PHP
That would be great, too. So that at nighttime the moon appears.
I’m having similar issues… though I am GMT-7 here in Southern California… the graph is showing the sun as set, when in reality it isn’t even mid-sky yet…
I tried changing that but it didnt work, yours is showing the same as mine, shouldnt yours be
showing 20:00 and not 18:00 then again your 2hrs ahead of gmt aint you, i aint got a clue? lol
