Hi. In Kristiansand we have two stations running Fresh and both are down at the moment.
The clientraw-data is uploaded as normal so this was strange.
Restart did not help. Only the yellow page with “Collecting data…” i visible.
Checking the Paulen site (https://www.paulen.no/wdisplay/FreshWDL.html) and my thought was confirmed:The sentral rutine may have stopped?
Fairfield stopped as well:https://www.fairfieldweather.info/
//perotto
http://weather.stenbergs.no
Yes, mine is unavailable too. Must be a problem with Yerren’s server.
Just to be pedantic, the content comes from the JSDelivr CDN service rather than a server belonging to Yerren. The point of these services is supposed to be to have many servers globally so that you don’t rely on a single server that could keel over.
The error from the page is:
“Could not load content for https://cdn.jsdelivr.net/gh/yerren/FreshWDL@master/css/opentip.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE”
…which either means the CDN service is currently down or Yerren has deleted his files. I suspect the former to be the case!
The .map file is optional, just used in the browser debugger for prettifying the css.
The error seems to be a missing comma in Globals.js at line 1656 - when the Finnish lang was added.
Edit - Though looking directly at the copy on JSdeliver, it does not have that problem! But it ends prematurely at the bg translation.
Edit2 - actually there seem to quite a few issues!
Same here … Bergen, Norway … just stuck on collecting data…
mine is ok here
Minneapolis USA.
hopefully he is adding dew point!!!
Looking in from Ireland it’s stuck too…
Really? working on my computer…(but not complaining)
I even tried to do F5 to make it stop.
That’s odd
BSM live data …on its way
Even tried a different browser
Well now you did it #-o…it is working on one page, but not on another… :-k
Strange this - works on one PC and not the other - both through the same router !
Only difference is Win 11 is on the worker.
Numerous ‘viewers’ to my site say its not working for them.
Mine also not working, just says “Collecting Data” and does nothing.
Doesn’t work for me, just stuck saying on its way, devices are windows 11 chrome and android chrome. Chrome console shows 3 js errors on windows 11 pc
My freshwdl doesn’t load, just the usual collecting data https://maghull.org.uk/freshwdl/freshwdl.html
errors from console are
Globals.js:1657 Uncaught SyntaxError: Unexpected identifier
WidgetsHandlers.min.js:1 Uncaught ReferenceError: useDict is not defined
at WidgetsHandlers.min.js:1:119195
WidgetsHandlers.min.js:1 Uncaught TypeError: Cannot read properties of undefined (reading ‘config’)
at initAll (WidgetsHandlers.min.js:1:229505)
at onload (freshwdl.html:15:28)
DevTools failed to load source map: Could not load content for https://cdn.jsdelivr.net/gh/yerren/FreshWDL@master/css/opentip.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
anyone figure out the glitch?
Looks like it’s sorted, mine is running normally again
Yep, seems sorted now. Thanks.
Bonjour,
Votre lien ne fonctionne pas : http://maghull.org.uk/e107_plugins/wdisplay/data/FreshWDLmaster.html
Serge
mine is back now…but the internet and power is off at school. “storm” last night #-o
Well - this site is working fine from Norway on 3.8.22
//perotto
