Fresh sentral script stopped 2. august?
https://Maghull.org.uk/freshwdl/freshwdl.html should now work even though the data is out of date.
Ok merci.
On 4. of august the two Fresh-stations i Kristiansand is still down.
So is several others…but some others are working…???
Do we have to modify our scripts to use other services?
(Looking forward to se this fixed.)
//perotto
http://weather.stenbergs.no
Just checked and mine still saying collecting data and never opens.
Ian
https://www.ndtech.org/weather/
Yours is working for me here, Ian. Try Ctrl-F5?
That did the trick. Working now. I was unaware of that shortcut (Ctrl-F5)
Thank you
48 hours later, it’s still down here.
Can’t check yours, the URL of your page doesn’t work. Have you tried Ctrl-F5?
It’s working now. On my laptop I had to do fn-ctrl-F5.
FYI: I need to change my signature. The page is now at https://daytonwx.com.
Wow…Ctrl+F5 did the trick !!
Thanks !!!
the basic cause is the cache loading the site files when faulty which means it failed to work, to sort this meant the cache has to be cleared to reload the correct files into cache
Ctrl F5 solved it on Windows/Chrome …but not on my phone…???
What is the trick for Android?
Strange…The Paulen site (https://www.paulen.no/wdisplay/FreshWDL.html) is ok on my Samsung S10 but my own site http://weather.stenbergs.no is still collecting data…??
//perotto Kristiansand Norway :o
update5.august … Black Magic?
Checked og my wifes Samsung/Chrome: OK !!!
Checked on a Samsung Galax Tab with Chrome: OK !!!
Update with newest chrome-APP om my S10 + reebooting: STILLE ONLY COLLECTING DATA…???
Any tips out there ? Settings ?
Update 6. august … Black Magic 2?
Installed two other browsers on my Samsung Galaxy s10: Firefox: Ok !!! and Samsung Internet: Ok !!! but wrong and awful colors.
So…Fresh script works fine all over on Android. Only problem is on my S10 - very strange.
Any tips …
My FreshWDL was also stuck on “loading data” like many other people’s but is now working fine again but when it restarted working a few days ago, instead of loading with “The Old School Weather” which I’d set up in my FreshWDLmaster.html file, it loaded with “FreshWDL” and my picture of clouds in the background which I also put in my FreshWDLmaster.html file had disappeared leaving a blank white background.
When I checked my FreshWDLmaster.html file I saw that it had been replaced by a different file dated 02/08/22 19:40 (UK BST) which didn’t have the 2 modifications I had originally made so I then modified the new file & all is now back to where it was before - see http://www.theoldschool.info
I see that my config.js file is also dated 02/08/22 19:40 and I haven’t changed it…
