I have followed the directions for uploading the clientraw.txt but I get this error.
I don’t know what I am doing. #-o.
Please help.
Jeff
San Diego, CA
Connecting to FTP server.
Connected.
220 Welcome, username and password please…
USER fischer1
331 Password required for fischer1.
PASSWORD=****
230 User fischer1 logged in.
CWD mint.e-rice.net
550 mint.e-rice.net: No such file or directory
141: 550 mint.e-rice.net: No such file or directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (67,15,6,96,215,10).
STOR clientraw.txttmp
550 clientraw.txttmp: Permission denied
141: 550 clientraw.txttmp: Permission denied
File uploaded at time :19:31:9
RNFR clientraw.txttmp
550 clientraw.txttmp: No such file or directory
141: 550 clientraw.txttmp: No such file or directory
The problem is that in the FTP set up you have the name of the server “mint.e-rice.net” plugged in instead of the name of the directory in the remote directory box so where you have
Ok, I think it’s working. I put /web in the Remote directory. This is what’s up loading now.
Connected.
USER fischer1
PASSWORD=****
TYPE A
200 Type set to A
CWD /web
250 CWD command successful
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (67,15,6,96,215,30).
STOR clientrawextra.txttmp
150 Opening ASCII mode data connection for clientrawextra.txttmp
226 Transfer complete.
File uploaded at time :18:11:30
RNFR clientrawextra.txttmp
350 File or directory exists, ready for destination name.
RNTO clientrawextra.txt
250 Rename successful
My web site is www.waterlilyweather.com and I dont see any thing.
Once it gets uploaded, is this were I put my serial number in the wdlconfig xml file?
The more I read about how to do this the more I get confused.
Jeff
http://www.waterlilyweather.com/clientraw.txt
thats there
you now need to upload the other files needed to your web site, like the .xml config file, the .swf flash movie file and the .html file
you can use wd’s built in ftp manager, see under action, manager our ftp web server
OK I have done both things. Weather Display upload files to your site folowed the direction and download WDL.
Still can not enter the s/n in wdiconfig.xml.
Thanks for your help…
My URL is waterlilyweather.com I think. I guest I did not upload The HTML file, the .SF file and the .XML file correct. I thought I did. My Mom is doing my web page. She tells me there not uploaded. Win I go back to manager our FTP web server all i get is wdisplay in the drop down box.
You have an index file uploaded about Water Lilies
and I assume you are Jeff?
You will need to upload the three files mentioned from the WDL download.
Now if you upload the HTML file named as it is in the download, index, it will overwrite your current page.
You may want to rename the file to something like WeatherLive.html then upload it (it won’t make any difference to WDL) just don’t rename the other two files…
Usually using an FTP client. Someone either uploaded or created the current index file that is there now… Most likely they created the file locally and then used FTP to upload it. If so they may be able to show you.
The other option would be to:
Click Control Panel and then select FTP/internet/metar/email and then Manual Upload/Run a program…
Click Choose the file and then locate the renamed WeatherLive.html file and then press Upload the file now.
Then do the same for the .xml file and the .swf file…
Pre- built configure question,
not sure how to set up the screenshots. the configuring WDL tells me alter the 2 lines in the index.html file. i dint know how to do this.
this is what my web site looks like. http://www.waterlilyweather.com/
for WDL, you need to create a different file name file
e.g live.html
you can do that with notepad.exe
and copy over the index.html file included with the WDL install files
then set the URL to the xml config file, by editing that file with notepad.exe, then saving it
then upload that file to your web site
Your main WD page appears to have been updated recently 6:21 PM Dec 14, 2005 and as you are West Coast that would appear to me to be recent…
Assuming you plan on using WeatherLive for the file name you would first right click on the file name, index.html, on your local computer where you unzipped it and then select “Rename” then alter the name to WeatherLive.html. Then you would again right click on the file and choose Open with, and in the list you should see Notepad then click that and you can alter the code contained in the file.
