The time updates, but not any thing else.
If I could may I suggest you start with some basics and first get WD uploading the main routine data…
Please review this FAQ and walk through your setup step by step…
http://discourse.weather-watch.com/t/13162
That would be the place to start and see if you can get WD working for you in that area…
your data does not look correct waterlily
straight lines for temperature etc
that should not be happening
do you have your barometer offset set correctly, etc?
Not sure where to put xml config file for the url.
May be you can show me.
you need to replace the word
mywebsite
with
waterlilyweather
and leave everything else as is
in the places where you find that
mywebsite
with
waterlilyweather
I did this.
How do i do this?
My WD is not updating. nothing works correct, God i fill like a jack ass i cant get it to work…
Maybe I am over my head with this. :oops: #-o #-o #-o
with those changes to the file, have you uploaded it as say live.html?
re the data in weather display
email me your settings files (see the FAQ for how to do that on this forum)
make sure no other software like weather link is running at the same time, too
I e-mailed you the files.
I thought you told me to rename to weatherlive.HTML
it does not matter what you name it as , you can name it what ever you like (except index.html, unless it not in the home page directory)
so you have uploaded weatherlive.html to your web site?
what is your email address?
i.e when did you email me the settings?
thanks
i see the problem in your setup
you have set to produce the clientraw.txt file (OK) but you have also ticked to use the clientraw.txt
which then means a ground hog day situation
so untick the , use clientraw.txt file, in the control panel, ftp/internet setup, Client/Server setup
i.e e bottom right hand side setting in this screen shot (you need to resize/move the screen via the scroll bars to see that setting in your setup)
Thanks, got that working. Still can not see my pre-built screenshot. http://www.waterlilyweather.com/
And I have extra temperature and humidity station and i can’t get the humidity to work correct or show.
