Strange, but why is this empty 24 uur per dag het actuele weer in Medemblik Reports at WU
2024 oké 2025 empty but this is oké 24 uur per dag het actuele weer in Medemblik History at WU
shoot me why
shoot me why
Go into your server, the pwsWD folder → wudata ->2025 and delete the .txt file year-2025.txt. Go back to reports and it will get rebuilt.
Good luck
Your 30/360 day graphs all stop at 31 December 2024, too. See No data in Reports since 29th Dec 2021? - #11 by pwsdashboard for a full list of files to rename/delete – for 2022 (and 20202!) read 2025, in your case. Then use “Load files”, as described.
done, now waiting for succes
Nop, did not work still empty 24 uur per dag het actuele weer in Medemblik Reports at WU
file is empty: Date,TemperatureHighC,TemperatureAvgC,TemperatureLowC,DewpointHighC,DewpointAvgC,DewpointLowC,HumidityHigh,HumidityAvg,HumidityLow,PressureMaxhPa,PressureMinhPa,WindSpeedMaxKMH,WindSpeedAvgKMH,GustSpeedMaxKMH,PrecipitationSumCM
Also the month file: Date,TemperatureHighC,TemperatureAvgC,TemperatureLowC,DewpointHighC,DewpointAvgC,DewpointLowC,HumidityHigh,HumidityAvg,HumidityLow,PressureMaxhPa,PressureMinhPa,WindSpeedMaxKMH,WindSpeedAvgKMH,GustSpeedMaxKMH,PrecipitationSumCM
Hi Soulmaster,
The link posted by @bitsostring normally solves these problems
It is a problem which occurs with some of the users but still no idea why.
If it does not work even after deleting all those files, I need the FTP user-id and a (temporary) password.
I can check and try to get it working again.
can’t send you a DM. not aloud .
Thanks for the mail with the ID and password.
All working now.
@ALL the solution-link from @bitsostring works OK but for future reference:
Solution
All 2025 files for the graphs / reports need to be removed
Step 1:
pwsWD/chartswudata/
remove or rename . . .Y.txt . . .YM.txt . . .Y.txtold . . .YM.txt.old
Step 2:
pwsWD/wudata/
the complete 2025/ folder should be removed (deleted or renamed)
and
the XXXXXXXX-metric-2025.arr need to be removed
The XXXXXXXX is your WU-ID
Step 3:
You should then use the pwsWD/PWS_module_test.php script to press bottom button “Load files”
There will be error messages, but only the first time you press the button.
All should be OK then.
my thanks is _great____/
Users that have an older version of wureports (like me) seem to have a subdirectory . . ./wureports/wuData with files WUID-year-YYYY.txt. I think this also needs to be deleted/renamed?
Yes, as it probably is recent.
The different older versions kept their data in other places.
