Brian,
At the bottom of the weather output html page (gardengate.dyndns.org:8080/weather/delandwx.html) where it says “click here for the last 24 hour graph”, the link is for a file named yesterdaygraph.png. The file that is actually placed into the directory is called yesterdaygraph.bmp. In case the problem isn’t obvious, the link is ‘broken’ since the file name is wrong.
Is this something I have control over? I looked all around, but it wasn’t apparent that I could do anything about the problem.
On another note:
I finally did get version 3.2 to crash (segmentation fault) after much fiddling around. However is was running quite happly for several days.
Thanks - John
wow, never noticed that… very odd indeed… :?
Does yours do that Chris?
yes i am
my fault
fixed for the next release
Thanks Brian. There are one or two more .bmp’s also. Might double check all of the filename extensions.
–John
hmmm, cought this one a bit late (busy with work :roll: ) But I have a yesterday2.png in my directory…
is that also a bit odd?
rgds
Johan
