XML data showing some bizare readings
It has said that the temprature is 1*c all day using the XML but the temprature is reading the correct reading elsewhere.
xml is a very finicky language
sounds like there might be a character in the data it does not like, or similar
can you post the source of the xml file here, thanks
The temp string is actually 1
- 21:51 PM 26/06/2004 7:23 17:12 12:34 1:07 Moon age: 8 days,2 hours,38 minutes,58% 06:49 UTC 20 March 2004 00:57 UTC 21 June 2004 16:30 UTC 22 September 2004 12:42 UTC 21 December 2004 07:19 UTC 3 January 2005 16:12 UTC 4 July 2004 22:55 UTC 1 July 2004 21:09 UTC 14 July 2004 03:00 UTC 14 October 2004 Eclipse Partial 03:04 UTC 28 October 2004 Eclipse Total 11 April 2004 Dry --- --- 10.13h DATE: 26 June 2004 51 21 26 06 2004 21 12 26 06 2004 3265 933 4 Days 14 Hours 37 Minutes 18 Seconds 4:58:32 PM 26/06/2004 255 255 255 255 255 255 -10 14 -10.0 12.0 12.0 69.8 4.7% 4.7% 979.8 979.8 7.6 4.1 2.1 7.6 7.6 4.1 2.1 7.6 329 50.0 50.0 -12.3 -12.3 90.0 0.0 18.3 18.3 -61.8 -61.8 1030.1 1030.1 1001.6 1001.6 35.2 9.8 19.0 35.2 42.6 11.8 23.0 42.6 11.3 1 63 5.0 11.8 14.5 13:01 PM 8.3 07:46 AM 11.8 8.3 07:46 AM 14.1 14:33 PM 81 00:05 AM 57 15:28 PM 21.6 55 7.8 13:26 PM 3.6 05:55 AM 14.5 13:01 PM 8.3 07:46 AM 53.8 12.1 53.6 12.0 11.8 5.0 11.8 11.8 14.5 8.3 7.8 3.6 14.1 8.3 8.7 53.2 41.0 58.1 46.9 21.6 -0.1 -0.2 12 53 22.2 22.2 17.1 17.1 19:14 PM 09:37 AM -10 14 -10.0 0.0 10.8 12.4 10.8 12.4 51.5 54.4 11.8 53.9 12.2 52.0 11.1 -0.1 9.3 14:04 PM 5.7 23:53 PM 17:32 PM 65 15:19 PM 12.4 13:18 PM 6.2 12:14 PM 14.0 15:19 PM 9.0 23:53 PM 13.9 15:19 PM 9.0 23:53 PM 20.7 17.1 23:36 PM 10:42 AM 2.6 0.9 295 WNW West north westerly 23.9 kmh WSW 15:16 PM 16.6 kmh W 13:57 PM 9.0 kmh WNW 21:33 PM 7.4 292 3.0 16.6 1.4 0.5 1 0 bft 12.9 4.9 9.0 4.0 0.0 9.0 12.9 avwindpoint1 avwindpoint1 1.6 0.6 WNW 1.0 17.8 4.9 9.6 17.8 6.6 2.5 4.6 2.1 0.0 4.6 6.6 10709.5 km 41070.2 km 89.0 Light Air 41.4 kmh W 12:14 PM 33.3 k 03:14 AM 1028 + 2 1028.1 20:06 PM 1018.9 01:13 AM 2 3 3 9 Steady 1028.1 mb 1018.9 mb 30.359 inches 1028.1 1028.1 -0 + 2 + 3 + 3 + 9 30.36 mostly clear and cooler. 8.71 1019.0 23:53 PM 1008.7 03:25 AM 84 0.0 0.000 in. 149.7 305.5 0.0 mm 0.0 0.0 0.0 0.0 0.0 8.7 mm 0 0 0.0 149.7 305.5 0.0 0.0 0.0 0.0 0.0 21.6 mm 21.6 mm 21.6 48.1 0.1 0.2 0.0 1.6 0.0 0.0 0.0 0.0 0 0.0 0.0 0 0 0 1000 0 % 0.0 0.0 0 0.0 0.0 0.0 0.0 255.0 0 0 255 255 255 255 0.0 0.0 0.0 0.0 -100.0 100.0 -100.0 100.0 11.8 63 14.5 8.3 81 57 00:01 AM 00:46 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 %hiws2000sen6tt% %lows2000sen6tt% 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 0.0 0.0 0 0 00:05 AM 00:05 AM 23.2 6.2 79.9 79.6 22.8 0.0 1031.1 1001.6 28 3 2004 19 21 6 6 2004 2004 18 8 6 6 1850 0 22 6 2004 14 5 2004 16.8 23 23 2004 9.0 C at: 06:00 on: 20 Jun 2004 10.4 C at: 18:00 on: 19 Jun 2004 28.2 C at: 06:00 on: 28 Mar 2004 28.4 C at: 18:00 on: 28 Mar 2004 16.8 8.3 79.9 34.6 21.6 5.8 1031.1 1001.6 19 21 6 6 2004 2004 26 23 6 6 2004 2004 22 6 2004 14 6 2004 16.8 23 23 2004 9.0 C at: 06:00 on: 20 Jun 2004 10.2 C at: 18:00 on: 19 Jun 2004 17.3 C at: 06:00 on: 09 Jun 2004 18.5 C at: 18:00 on: 08 Jun 2004 14 -20.0 -20.0 -20.0 -20.0 -20.0 -20.0 -20.0 -20.0 -20.0 -20.0 8.3 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 100.0 14.5 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 -100.0 00:46 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:01 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 00:05 AM 0 81 57 00:05 AM 15:28 PM 0 0 0 0 0 0 0 0 0 0.0 -100.0 100.0 0 0 0 0 0 0 % %wmr918/68extrahum% %wmr918/68extrahum2% %wmr918/68extrahum3% %wmr918/68extratemp% %wmr918/68extratemp2% %wmr918/68extratemp3% %wmr918/68extratemphigh% %wmr918/68extratemphigh2% %wmr918/68extratemphigh3% %wmr918/68extrahumhigh% %wmr918/68extrahumhigh2% %wmr918/68extrahumhigh3% %wmr918/68temphightime% %wmr918/68temphightime2% %wmr918/68temphightime3% %wmr918/68extratemplow% %wmr918/68extratemplow2% %wmr918/68extratemplow3% %wmr918/68extrahumlow% %wmr918/68extrahumlow2% %wmr918/68extrahumlow3% %wmr918/68templowtime% %wmr918/68templowtime2% %wmr918/68templowtime3% %wmr918/68extrahumhightime% %wmr918/68extrahumhigh2time% %wmr918/68extrahumhigh3time% %wmr918/68extrahumlowtime% %wmr918/68extrahumlow2time% %wmr918/68extrahumlow3time% %wmr918/68tempbat3% %wmr918/68tempbat2% %wmr918/68tempbat1% %wmr918/68tempbat% %wmr918/68consbat% %wmr918/68rainbat% %wmr918/68windbat% 0 0 0 0 0 0 calm-rippled sea
i have made some improvements with the temp and dew tags in 10.13i
try that version…
I have upgraded to the latest version 10.13i and the same problem is still there.
what is your current temperature?
maybe try a download again, as you might still not have got the change i made…maybe
The version of WD is 10.13i, and the current temp is 15.5. But the current temp has changed all night but the XML and the customtags are all saying 1 for the while.
just checked mine
i have the same problem
not sure when or why that started
LOL
i will fix in the next hour or so
found the problem
i had redone the routine, to fix an issue with the units, but left some code there ( i needed to have scrolled down to see it)
uploading a fix as 10.13j now
(been playing hockey this afternoon (in the rain and 40 knot winds))
sorry about that introduced bug
kewl, thanks. That sounds rather windy. I guess ur living up to your name. Been sitting here redoing your XML file for you like I prommised. You’re right, there is an awfull lot to it. I should have it finished tonight or tomorrow after i get back from basketball.
it was probably gusting 30 knots where i was playing hockey, but we had gusts to 41 knots here at home , and it nearly blew the kids trampoline into the house, LOL (itwas upside down, 1cm from the glass sliding door where it came to rest (i wondered if i should have put it upside down before i left home))
but winds gusting to 45 knots is a commen occurence around here
It has to start gusting to 55 knots before you can say its getting windy around here!, LOL
