Wxsim, plaintext,decimals
Is it possible the get the decimals on high low temp at plaintext ?
example High:24,2 low 13,7
Nikolas
I don’t think there’s a way to do that. I’m not sure it’s that useful anyway. When you’re displaying numbers that are likely only accurate to within a degree or two at the best of times, adding would imply a level of accuracy that doesn’t really exist. In any case humans can’t really distinguish between decimal places in temperatures, e.g. does 24.2C feel any different than 24C?
yes that is true…
I was wondering if can be done to make the forecast compare script more"accurate" since it compares the decimal high temp from wd with the absolute temp of the plaintext … anyway thxs for your reply :grinning_face:
