WXSIM forecast saratoga template minor modification
I’m using Saratoga-Weather template to present the WXSIM’s forecast. I did minor modifications so far but now I’m stuck since I’m not familiar with PHP at all.
I’d like to add a date (e.g. 27.12. or Dec.27 or similar) nearby the day’s name (above the icon):
Is this feasible?
Thanks!
I don’t think there is an easy way to do this as Ken’s parser does not allow for it. It will be quite a change as each date will have to be calculated and added.
Maybe Ken will consider adding this in an update.
For that particular script, I do not think it is achievable, as that script looks at Day and Night Data produced by WxSim For Day (06:00 to 18:00) and Night (18:00 to 06:00) The night portion over-lapse (2) two days.
Kindest regards,
Tony
Tony is correct – the data for actual date (dd-mm-yyyy) does not exist in the plaintext.txt – only the day names in english, so not practical to add the dd.mm to the display via the script. Sorry.
No problem, thanks for your answers :+1:
