WXSIM Forecast is always the same
Hi All
My WXSIM runs a forecast every 2 hours; since yesterday, it’s always been the same and is inaccurate and outdated.
plaintext.txt (2.3 KB)
I’ve tried deleting the plantext file and running forecast again, still same result.
I have attached said forecast. Many thanks for any help given.
Chris
https://vinesweather.com/wx_lvn_wxsimPP.php
This is the uploaded plaintext.txt file
   WXSIM text forecast for The Vines, initialized at  9:00 AM 06 Feb, 2025
 _______________________________________________________________________________
 Today: Mostly sunny in the morning, becoming sunny in the afternoon. High 37. UV
 index up to 12. Wind southwest around 10 kph, gusting to 30 kph, in the morning,
 becoming south around 17 kph, gusting to 37 kph, in the afternoon.
 Tonight: Partly cloudy in the evening, becoming fair to partly cloudy after
 midnight. Low 22. Wind east-southeast around 19 kph, gusting to 37 kph, in the
 evening, becoming 8 kph after midnight.
 Friday: Partly cloudy. High 36. UV index up to 10. Wind south-southwest around
 10 kph, gusting to 27 kph.
 Friday night: Partly cloudy. Low 23. Wind east-southeast around 6 kph in the
 evening, becoming  near calm after midnight.
 Saturday: Partly cloudy in the morning, becoming partly to mostly sunny in the
 afternoon. Hot. High 38. UV index up to 12. Wind west around 13 kph, gusting to
 31 kph.
 Saturday night: Mostly cloudy. A slight chance of rain. Low 22. Wind west around
 9 kph, gusting to 26 kph. Chance of precipitation 20 percent. Precipitation
 mostly less than 2 mm.
 Sunday: Mostly sunny in the morning, becoming partly cloudy in the afternoon.
 High 32. UV index up to 11. Wind west around 15 kph, gusting to 33 kph.
 Sunday night: Mostly cloudy to cloudy in the evening, becoming partly cloudy
 after midnight. Low 19. Wind west-southwest around 4 kph.
 Monday: Sunny. High 32. UV index up to 11. Wind west-southwest around 14 kph,
 gusting to 34 kph, in the morning, becoming 20 kph, gusting to 36 kph, in the
 afternoon.
 Monday night: Clear. Low 17. Wind south around 10 kph, gusting to 31 kph.
 Tuesday: Sunny. High 32. UV index up to 12. Wind south around 14 kph, gusting to
 34 kph, in the morning, becoming 21 kph, gusting to 44 kph, in the afternoon.
 Tuesday night: Clear. Breezy. Low 16. Wind east-southeast around 23 kph, gusting
 to 44 kph, in the evening, becoming 15 kph, gusting to 28 kph, after midnight.
 Wednesday: Sunny. High 33. UV index up to 10. Wind east-southeast around 14 kph,
 gusting to 39 kph.
 Wednesday night: Clear. Breezy. Low 18. Wind east-southeast around 24 kph,
 gusting to 39 kph, in the evening, becoming 17 kph, gusting to 31 kph, after
 midnight.
 * THIS FORECAST WAS MADE IN AUTOMATED MODE AND MAY BE LESS ACCURATE THAN OTHERWISE *
If there is a problem, it is with the data from WXSIM as the script generates what is in the plaintext.txt file.
The first remark, it is 10 hours old , current time at your place 16:00, forecast is generated at 06:00
Will check later to see if there is another plaintext.txt file and what the differences are.
Seems that your WXSIM file is stalled.
It is uploaded frequently but the contents is not updated with a new forecast.
contents of "../plaintext.txt", processed as filetype "text file"
Filetime (UTC): 2025-02-06T08:30:18+00:00 which an age of 0 hrs 01 min 30 seconds
Contents processed:
Many thanks Wim. I changed the forecast to not use EMCWF. That seems to have changed the forecast, understandably but a little more accurate I think.
That does not explain why there is only an old plaintext.txt uploaded from your PC.
The file is uploaded every so many minutes but the contents of the file is old.
You have to check on your PC what is inside the plaintext.txt file in your WXSIM folder.
If that is also old data
→ the problem is with WXSIM
→ and/or your changes, maybe you set the forecast to manual
If it is recent data in the PC and old data on your website
→ check the ftp-log and settings in WeatherDisplay
Many thanks, Wim. I’ve gone through the settings, I can’t seem to find where the problem might be.
The last 2 forecasts today, one at 0805, the next 1005 changed only in in the max temp today from 36 to 35. However, the dates and time stamp are the same:
WXSIM text forecast for The Vines, initialized at 8:00 AM 07 Feb, 2025
I continue to try and sort it out.
Chris
Check the bottom lines of your plaintext.txt generated by WXSIM
No GFS/ECMWF or READY data found -
make sure this is checked for download in WXSIMATE
and for import in WXSIM
If you ask WXSIM to generate a forecast without the official forecast data you only get these very dense results.
If you’re no longer mixing GFS and ECMWF data then the ‘mixed’ data file won’t be re-created so it will have old data in it. You probably need to switch WxSim back to using the ‘unmixed’ GFS only file by changing the filename it’s looking for.
Two possibilities: (1) WXSIMATE is not running (or the scheduler is off), or (2) this is a result of a problem that started about a day ago with Chris’ GFS and ECMWF processing. He hopes to fix that in the next day or so. Meanwhile, the Bohler GFS is working.
Tom
