WXSIM and Forecast Compare Script
Hello,
Should I be seeing actual temperature values under the “high” and “low”?
Testing Forecast Comparison Script Times
The time zone = America/New_York
Config’s nightend setting = 04:50
Config’s nightstart setting = 16:50
Logging with actual comparison time vs WxSim’s time.
Checking forecastAM.log
The most recent entry in forecastAM.log is timestamp 1302526804 which is 04-11-11 9:00 am
This night end time = 04/11/2011 04:50 and that timestamp = 1302511800
This night start time = 04/11/2011 16:50 and that timestamp = 1302555000
Using the script’s present logic it’s a day forecast and we should see high temps and headings in the first column
High Low High Low High Low
Checking forecastPM.log
The most recent entry in forecastPM.log is timestamp 1302538687 which is 04-11-11 12:18 pm
Checking forecastEV.log
forecastEV.log does not exist.
Checking forecastNI.log
forecastNI.log does not exist.
The time zone when all is said and done = America/New_York
Thanks!
www.BarrowCountyWeather.com
Al
Al,
No, that’s just a little test script that we were using to figure out an issue when comparing WU forecasts. Just a debugging tool and it never had temps in it.
  • Jim
