https://weather.scottsworld.info/wxgraphs/wxgraphs.html
Last 31 day graphs none are working, flat line
Only thing I have changed recemtly was historical rain fall and it is working.
Have you checked what is in the clientraw file used for this data to see if there is anything wrong in it? You can see which one by looking at the PHP code for the graph.
The monthly files use clientrawdaily which I opened and has a lot 0.0’s in it, looks like it is in metric but if the first two lines are temp c something is wrong as they all say 20.6. I don’t how often it updates but the other clinetraw filles when i click between them my program says have updated, load new version, that one does not.
If you go here Saratoga-Weather.org - Weather-Display clientraw*.txt parser and put in the url for your clientraw files you can see what all the entries mean.
As i thought clientrawdaily.txt is not updating properly since about last Saturday the 9th
Data from https://www.weather.scottsworld.info/clientrawdaily.txt
Raw Data
12345 36.3 36.3 32.1 29.6 24.9 24.9 29.1 31.7 13.5 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 19.0 12.3 14.2 13.9 11.7 5.2 5.7 9.4 13.5 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 30.4 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1000.7 995.5 996.5 995.7 1005.7 1007.2 1001.4 1002.3 1002.9 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 1004.3 0.2 2.5 2.2 3.2 4.2 0.9 0.5 0.7 0.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 47.2 20.3 360.0 268.1 267.8 220.6 313.5 47.2 47.2 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 2.0 11.6 0.8 0.3 0.0 1.8 61.2 61.2 8.1 3.5 0.0 44.2 25.0 20.0 32.0 34.0 18.0 30.0 36.0 37.0 39.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 13 11 16 0.0 32.8 19.0 12.3 32.1 32.6 23.3 14.5 29.2 29.3 21.3 14.1 26.1 26.9 20.9 15.9 22.3 20.1 11.7 5.4 21.5 21.8 11.1 5.7 25.0 26.0 13.0 9.6 0.0 1000.6 1000.7 1000.5 999.9 994.3 995.5 996.4 997.3 993.7 996.5 997.9 998.7 994.3 995.7 997.8 1000.7 1000.5 1005.7 1009.1 1010.0 1006.6 1007.2 1006.7 1006.2 1000.8 1001.4 1002.5 0 11 25 42 15 14 20 36 25 17 32 56 31 27 34 49 35 13 18 28 15 14 30 37 14 14 36 44 0 0 18 19 28 67 49 98 18 72 96 78 35 66 58 59 122 105 124 131 171 50 58 56 5 110 78 77 0 0 0 0 1 7 0 0 4 4 0 0 5 7 4 7 2 4 0 0 5 4 0 0 1 0 0 0 0.0 28.0 0.0 0.0 949.0 93.0 0.0 0.0 1027.0 47.0 0.0 0.0 949.0 37.0 0.0 0.0 1020.0 37.0 0.0 0.0 983.0 32.0 0.0 0.0 981.0 32.0 0.0 5.0 0.0 0.0 0.0 0.0 4.4 0.0 0.0 0.0 4.4 0.0 0.0 0.0 4.4 0.0 0.0 0.0 4.4 0.0 0.0 0.0 4.6 0.0 0.0 0.0 4.9 0.0 0.0 0.0 29.7 8.2 23.3 17.4 2.4 0.6 0.7 23.4 26.0 18.1 5.8 26.2 26.6 !!D10.37S138!!
Extracted Data in Fields
Field # Label Type/Unit Value
0 Beginning of file Label 12345
1 Hi-Temp Month 01 Celsius 36.3°C = 97.3°F
2 Hi-Temp Month 02 Celsius 36.3°C = 97.3°F
3 Hi-Temp Month 03 Celsius 32.1°C = 89.8°F
4 Hi-Temp Month 04 Celsius 29.6°C = 85.3°F
5 Hi-Temp Month 05 Celsius 24.9°C = 76.8°F
6 Hi-Temp Month 06 Celsius 24.9°C = 76.8°F
7 Hi-Temp Month 07 Celsius 29.1°C = 84.4°F
8 Hi-Temp Month 08 Celsius 31.7°C = 89.1°F
9 Hi-Temp Month 09 Celsius 13.5°C = 56.3°F
10 Hi-Temp Month 10 Celsius 30.4°C = 86.7°F
11 Hi-Temp Month 11 Celsius 30.4°C = 86.7°F
12 Hi-Temp Month 12 Celsius 30.4°C = 86.7°F
13 Hi-Temp Month 13 Celsius 30.4°C = 86.7°F
14 Hi-Temp Month 14 Celsius 30.4°C = 86.7°F
15 Hi-Temp Month 15 Celsius 30.4°C = 86.7°F
16 Hi-Temp Month 16 Celsius 30.4°C = 86.7°F
17 Hi-Temp Month 17 Celsius 30.4°C = 86.7°F
18 Hi-Temp Month 18 Celsius 30.4°C = 86.7°F
19 Hi-Temp Month 19 Celsius 30.4°C = 86.7°F
20 Hi-Temp Month 20 Celsius 30.4°C = 86.7°F
21 Hi-Temp Month 21 Celsius 30.4°C = 86.7°F
22 Hi-Temp Month 22 Celsius 30.4°C = 86.7°F
23 Hi-Temp Month 23 Celsius 30.4°C = 86.7°F
24 Hi-Temp Month 24 Celsius 30.4°C = 86.7°F
25 Hi-Temp Month 25 Celsius 30.4°C = 86.7°F
26 Hi-Temp Month 26 Celsius 30.4°C = 86.7°F
27 Hi-Temp Month 27 Celsius 30.4°C = 86.7°F
28 Hi-Temp Month 28 Celsius 30.4°C = 86.7°F
29 Hi-Temp Month 29 Celsius 30.4°C = 86.7°F
30 Hi-Temp Month 30 Celsius 30.4°C = 86.7°F
31 Hi-Temp Month 31 Celsius 30.4°C = 86.7°F
32 Lo-Temp Month 01 Celsius 19.0°C = 66.2°F
33 Lo-Temp Month 02 Celsius 12.3°C = 54.1°F
34 Lo-Temp Month 03 Celsius 14.2°C = 57.6°F
35 Lo-Temp Month 04 Celsius 13.9°C = 57.0°F
36 Lo-Temp Month 05 Celsius 11.7°C = 53.1°F
37 Lo-Temp Month 06 Celsius 5.2°C = 41.4°F
38 Lo-Temp Month 07 Celsius 5.7°C = 42.3°F
39 Lo-Temp Month 08 Celsius 9.4°C = 48.9°F
40 Lo-Temp Month 09 Celsius 13.5°C = 56.3°F
41 Lo-Temp Month 10 Celsius 30.4°C = 86.7°F
42 Lo-Temp Month 11 Celsius 30.4°C = 86.7°F
43 Lo-Temp Month 12 Celsius 30.4°C = 86.7°F
44 Lo-Temp Month 13 Celsius 30.4°C = 86.7°F
45 Lo-Temp Month 14 Celsius 30.4°C = 86.7°F
46 Lo-Temp Month 15 Celsius 30.4°C = 86.7°F
47 Lo-Temp Month 16 Celsius 30.4°C = 86.7°F
48 Lo-Temp Month 17 Celsius 30.4°C = 86.7°F
49 Lo-Temp Month 18 Celsius 30.4°C = 86.7°F
50 Lo-Temp Month 19 Celsius 30.4°C = 86.7°F
51 Lo-Temp Month 20 Celsius 30.4°C = 86.7°F
52 Lo-Temp Month 21 Celsius 30.4°C = 86.7°F
53 Lo-Temp Month 22 Celsius 30.4°C = 86.7°F
54 Lo-Temp Month 23 Celsius 30.4°C = 86.7°F
55 Lo-Temp Month 24 Celsius 30.4°C = 86.7°F
56 Lo-Temp Month 25 Celsius 30.4°C = 86.7°F
57 Lo-Temp Month 26 Celsius 30.4°C = 86.7°F
58 Lo-Temp Month 27 Celsius 30.4°C = 86.7°F
59 Lo-Temp Month 28 Celsius 30.4°C = 86.7°F
60 Lo-Temp Month 29 Celsius 30.4°C = 86.7°F
61 Lo-Temp Month 30 Celsius 30.4°C = 86.7°F
62 Lo-Temp Month 31 Celsius 30.4°C = 86.7°F
119 Baro Month 26 hPa 1004.3 hPa = 29.66 inHg
120 Baro Month 27 hPa 1004.3 hPa = 29.66 inHg
121 Baro Month 28 hPa 1004.3 hPa = 29.66 inHg
122 Baro Month 29 hPa 1004.3 hPa = 29.66 inHg
123 Baro Month 30 hPa 1004.3 hPa = 29.66 inHg
124 Baro Month 31 hPa 1004.3 hPa = 29.66 inHg
