Hi All,
I have an unusual problem with my wxcanada.php page. Nothing shows on the page except the heading and menu. I have updated ec-radar and ec-forecast and even setup a new page. It must be something stupid but I’ll be barn if I can figure it out. :oops:
http://www.johnsnhweather.com/wxcanada.php
Any help would be appreciated.
John
code.txt (2.82 KB)
Your missing the ajax-dahsboard.php In your coding. Your dashboard works fine here…
http://www.johnsnhweather.com/ajax-dashboard.php
try adding this to your main index file that you posted
<?php include_once("ajax-dashboard.php"); ?>
Hi Mark.
The dashboard is working on the index page. The problem is on my wxcanada page. The Canadian radar and forecast are not showing up.
John
You have some testtags errors. Take a look here for that page. May not be the fix, But i’d take a look at that those.
http://www.johnsnhweather.com/wxcanada.php?sce=view
Hi Mark,
I’m not sure about those errors, I’m not a real techie, they seem to be on every page? The wxcanada page is the only one not working.
John
the top part of your testtags.php file has this…
if ( isset($_REQUEST['sce']) && strtolower($_REQUEST['sce']) == 'view' ) {
//--self downloader --
$filenameReal = __FILE__;
$download_size = filesize($filenameReal);
header('Pragma: public');
header('Cache-Control: private');
header('Cache-Control: no-cache, must-revalidate');
header("Content-type: text/plain");
header("Accept-Ranges: bytes");
header("Content-Length: $download_size");
header('Connection: close');
readfile($filenameReal);
exit;
Mine looks like this…
if ( $_REQUEST['sce'] == 'view' ) {
$filenameReal = $_SERVER["PATH_TRANSLATED"];
$filenameLcl = substr($PHP_SELF,1);
if ($mode == 'download' ) {
header("Content-type: application/x-download");
header("Content-Disposition: attachment; filename=$filenameLcl;");
} else {
exit;
Not sure If you try and change yours, that It may fix those errors your getting. Thats also the area your errors are coming from
Hi Mark,
Most unusual — I made the changes you suggested and I still get the errors. 8O
I’m really confused, I don’t understand how the wxcanada page would just stop working. 8O
John
ktrue
2 June 2009 19:22
8
Mark,
Your self-downloader script is an earlier version that may not work on all PHP installations … the current one is what he had
exit;
John, your wxcanda.php page probably has a PHP error in it somewhere after
<div id="main-copy">
<div class="column-dark">
which are the last HTML bits rendered on the page. From your wxcanada.php page, copy all the stuff between
and the
and paste it into a
in a new post on this thread … then we can spot what might be in error.
PHP is funny sometimes … it will just stop executing when it encounters a syntax error in an included file, but may not cough up an error message into the HTML page.
Ken
ktrue
2 June 2009 19:39
10
No problem, Mark! There has been much evolution of the code over time as new issues were encountered with different PHP installations. The $_SERVER[‘PATH_TRANSLATED’] worked fine on *nix servers, and not on ISS servers (thanks M$).
The change to FILE accommodated all installations as it always returned the real file name to be used.
Also, the global $PHP_SELF isn’t automatically set in PHP5 installations, so more recent code has a
if (!isset($PHP_SELF)) { $PHP_SELF = $_SERVER['PHP_SELF']; }
in it to handle that.
Ken
Hi Ken,
I have included the code below,
<?php
$site = 'NAT';
$lang = 'fr';
if (isset($_REQUEST['site'])) { $site = $_REQUEST['site']; }
if (isset($_REQUEST['lang'])) { $lang = $_REQUEST['lang']; }
include("http://www.johnsnhweather.com/ec-radar.php?inc=Y&site=$site&lang=$lang&linkto=$PHP_SELF");
<?php
$doIncludeWU = true;
include("ec-forecast.php"); ?>
<p> </p>
</div><!-- end column-dark -->
</div><!-- end main-copy -->
<?php
include("footer.php");
# End of Page
John
Hi Ken,
I made two changes but still no go.
New code below
<?php
$site = 'NAT';
$lang = 'fr';
<?php
<?php
# End of Page
John
ktrue
3 June 2009 02:59
13
John,
I’d use a slightly different method to include the EC radar by using
<?php // fetch fresh national radar image if needed
$_REQUEST['site'] = 'NAT';
$doPrint = false;
include_once("ec-radar.php");
<img src="<?php echo $radarDir . 'radar-' . $_REQUEST['site'] . '-0.png'; ?>"
alt="Radar, courtesy of Environment Canada"
title="Radar, courtesy of Environment Canada" />
then for the ec-forecast, use
<?php
$doInclude = true; // handle ec-forecast and WXSIM include also
$doPrint = true; // ec-forecast.php setting
include_once('ec-forecast.php'); ?>
That should put the national radar image (static) and the current ec-forecast on the same page.
Ken
Thanks Ken,
That took care of the problem, all is good at johnsnhweather.
John
