Is it just me who quite often cannot access this forum?
For example, about 15 minutes ago, I tried several times and I always got a DNS error or a simply page that the server cannot be accessed. I got this also a few days ago and it seems like a relatively common problem in my case. Does anyone else have the same experience? Any ideas what could be causing it?
The refresh interval is every 3 hours, with a retry (if failed) at 60 minutes. ns2.weather-dns.net refused a ‘dig’… that’s a bit unusual.
It could be the unique timing of your DNS fails to get the zone for weather-watch.com for some reason, so the lookup ‘expires’ (becomes unavailable) until a successful zone can be fetched and used.
I am not an expert on servers, but just to clarify a bit more, it is not the case that it would try to load the page and time out, I simply get the error and connection refused screen as soon as I click the link for the forum in my favorites.
The “got a DNS error or a simply page that the server cannot be accessed” and “get the error and connection refused screen” sound like different issues.
The first sounds like a failure in the DNS lookup for the weather-watch.com IP address.
The second sounds like the DNS lookup worked, but that the actual weather-watch.com server declined the connection.
Either can be caused by lossy packets from your IP to the IPs of the DNS and/or the weather-watch.com server itself. Are you having the issue with other websites?
I was writing a post where I appologized that I dont remember exactly what the error was and that next time I will write it down. And what a surprise, I hit the Post button and “bang” there I have it again… so I copied it down, I even opened the more details link to see what exactly is happenning, here it is:
This webpage is not available
ERR_NAME_RESOLUTION_FAILED
Hide details
The webpage at http://www.weather-watch.com/smf/index.php?action=post2;start=0;board=6 might be temporarily down or it may have moved permanently to a new web address.
Reload this webpage
Press the reload button to resubmit the data needed to load the page.
and just to add to that, reloading does not help, it simply starts working after some time, but if I just reload the page immediately it doesnt help and it stays like this for irregular time interval (usually like 10 minutes, sometimes more, sometimes less)
The error indicates that he’s not getting an IP for weather-watch.com and in that case tracert can’t do anything. Better to run nslookup for his default dns and maybe google 8.8.8.8 dns.
Me either, and I’m always checking for spammer registrations. The server is in Germany so you would think Jachym would have an easier connection than we do :?
