Since the last update wunderground.com is not receiving the data periodically … I do not know if it is a problem with wd or the web
cronwdwu.exe
which sends the data to wunderground
has not been updated for over a year (check the modified date/time)
so its nothing to do with any version of WD but WU often has problems
The doubt arose when the problems coincided with the update. Thanks for the quick reply
WU must be having data problems
I notice mine has not udpated for a while either
https://www.wunderground.com/dashboard/pws/IFRANKLI1
you can check the file
sentwudata.txt
to see the latest data sent
for my data
even though it says updated 45 minutes ago
the real time data is updating
and when i use the mouse over on the graph, the data is up to date more than 45 minutes ago
looks like its confirmed it is a wunderground problem that is being worked on:
https://www.wxforum.net/index.php?topic=40763.25;topicseen
wunderground have fixed it now
( I have not changed anything)
