Wunderground Almanac has stopped working. I’m not sure how many days since it stopped.
If I click on View Panel > Wunderground Almanac > Canada the screen does not respond. See screen shot below.
its because of the change in the url by wunderground to use https
(you will see an error about moved permanenlty under view ,program event log)
I will fix and upload an update
Brian,
Thank you very much for your prompt reply and attention to this!
new update ready
but it is working more than it was
so not sure why you say still not working
it worked OK here for the city I selected
I will test the same city you have selected here
It does not download the data. Previously, if I opened View Panel >Wunderground Almanac it would download the data and at the top of the screen would appear the Normal and Record Maximum and Minimum temperatures.
All that is shown now is four instances of — as you can see on the attached screenshot.
yes, but in your initial post, it would not even list a city
I have fixed that
I have tested here a random city and it works
eg
arizona
chandler
you should not have ticked
use this global id number
by using the search function
it lists those cities
selecting the second one in the list works
(make sure to not have ticked use global id)
You’re right. It works for Chandler, Arizona. It also works for Fredericton Cda Cs but does not work for Fredericton.
How odd.
If I search for Oromocto (Which is near Fredericton) I get two possibilities - Oromocto, Canada and Oromocto West, Canada
It works for both.
Oddly enough the only station that does not seem to work is Fredericton. It worked before.
Anyway, I will set it to another station close by.
Thank you very much for looking at this. It appears that the error is not in WeatherDisplay but is somehow related to the particular station I was using in the past.
How strange that it was working with that station (Fredericton) until a few days ago and then stopped working, while all other stations are working…
will most likely then be a problem with wunderground
