Hi, my website page has stopped populating my history data - http://www.derbyweather.co.uk/wuhistory/wxwuhistory.php
Has Weather Underground stopped supporting this?
Thanks and regards
no mine is working fine at the moment, have you made any changes lately? and are you still uploading to WU
Your station data at Wunderground is correct as seem on your station page
These are the debug errors from the download script which should fetch your WU-data
I removed your WU_API-key from the text
<!-- curl fetching 'https://api.weather.com/v2/pws/observations/all/1day?stationId=IDERBY120&format=json&units=e&apiKey=__API_KEY_&numericPrecision=decimal' -->
<!-- HTTP stats: RC=401 dest=104.77.118.122 port=443 (from sce=185.229.21.108)
Times: dns=0.001 conn=0.008 pxfer=0.091 get=0.043 total=0.135 secs -->
<!-- headers returned:
HTTP/1.1 401 Unauthorized
Mime-Version: 1.0
Content-Type: text/html
Content-Length: 313
Expires: Wed, 27 Mar 2024 10:59:57 GMT
Date: Wed, 27 Mar 2024 10:59:57 GMT
Connection: keep-alive
Content-Security-Policy: default-src 'none'
X-Content-Type-Options: nosniff
Strict-Transport-Security: max-age=86400
<!-- day cache ./cache/wuday-20240327-IDERBY120-e.json updated. 313 bytes saved. -->
The script does not get any recent data from WU.
First you should check your Wunderground Member panel, login and check your ASPI-key status.
Seems your key is invalid.
<HTML><HEAD>
<TITLE>Access Denied</TITLE>
</HEAD><BODY>
<H1>Access Denied</H1>
You don't have permission to access "ttps://api.weather.com/v2/pws/observations/all/1day" on this server.<P>
Reference #18.76764d68.1711538042.9bff75c
</BODY>
</HTML>
Thanks for the information
Thank you Wim - your time and analysis are very much appreciated
