WU report not update
Why is my WU report no longer updating? It has been stuck since December 31, 2024?
my report is doing the same thing
Sometimes it starts working after a few days, otherwise see No data in Reports since 29th Dec 2021? - Internet / PWS Dashboard 2012 - Weather-Watch Forum
Remove all 2025 files in this case. . .
Just delete the 2025 folder and the 2025 file and it will reload and be fine.
Jim
This?
The same thing has happened to me since December 30, 2024
Yes, and IEJBY10-metric-2025.arr
Do I need to do anything further from here or will it update itself?
Thanks. It worked. The data for January 1st is on.
Same problem. Data from 31. december missing.
all working good.!!!
Just no 31st december yet
Good. I don’t know how to solve the missing 31 December, though :slightly_frowning_face:
Go into the 2024 folder and there are all the ‘daily’ file folders, at the end of all the folders is a file like: KGABLUER41-year-2024.txt, Delete that and it will rebuild with Dec 31.
Jim
This file?
Yes, but you might want to rename it and then delete it after you see all is well.
Jim
