if using a rain gauge that comes with a ws2310 is there any settings that need to be changed?
There shouldn’t be if WD is set up with the WS2310 as the main weather station input.
I left all those setting alone when I set mine up.
If WD is showing your rain readings going up in 0.5mm steps and they correspond the readings on the WS2310 display then you should be good.
