Hi - any ideas? I have a WS2300. Is there any possilbilitiy to add a sun or light sensor beside the WS and integrate the data in the WD-SW?
thanks for inputs
peter
yes
by using the solar sensor from http://www.hobby-boards.com and integrating with either a http://www.labjack.com U12 or a dallas 1 wire adaptor (i.e usb or serial)
see in the section hints and tricks on this forum and do some searches on this forum too re solar sensor
Brian, thanks for fast answer!
As I browsed through your hints the appetite came with the sensors offered (solar,lightning, leave wetness). Is it possible to add all 3 sensors to the WS 2300 station?
As I’m not an electronics pro, I search for easy solutions. Can one start with one Dallas USB 1 wire and the solar module and add later the others (USB Hub?)
thanks peter
yes, you could add all those…
either by using the labjack (uses screw terminals, and its USB too, and faster updating) or the dallas 1 wire adaptor (serial or usb)
