I have read through this thread again and downloaded the manual
the ip address 192.168.0.9 in the session status is the ip of the computer accessing the camera not the camera ip
you client software is using 192.168.0.3 and is giving you a picture, I assume you have made that a fixed ip in the camera, and that port forwarding is enabled for port 88 in your router.
I would try 192.168.0.3:88 instead of 192.168.0.9:88
Using http://192.168.0.3:88/videostream.cgi?user=scatfus&pwd=mesav*8 in a browser window doesn’t work (attached).
No, port forwarding is not enabled. Do I need that just to do what I’m trying to do, see my own camera on my own home-networked computer? My router instructions say “The SBG6782-AC can use port forwarding to provide services to Internet users outside the home”.
You miss the 8 in the link…
Yes you need to forward the port in the router…
As long as you put the port number in the URL and are on the same network you don’t need to port forward. Port forwarding is only needed if you are outside your home network and want to access devices on your home network.
Thanks hankster. What I thought.
Double check the Foscam IPClient again and make sure the IP hasn’t changed on the cam.
I swapped my cams today and WD won’t connect now either…not sure whats going on, this was all working…I had to change the IP and now WD just will not start the preview.
the version of wdwebcamcapture.exe has not changed in a year now
I know…seems Amcrest changed the firmware. I think WD needs to be modified to work with the cam.
Are you familiar with Digest Authentication?
there is a newer version of the wdwebcamcapture program
http://www.weather-display.com/downloadfiles/wdwebcamcapture.zip
I would need access to a cam (i.e via port forwarding)
All of a sudden Weather-Watch is issuing certificate errors…can’t do anything without getting the error.
Brian, I cannot run the new webcam exe file, says I don’t have permissions or paths to run it.
But I can get you access to my webcam…I will iron out the details and email you the necessary info.
with the help of Dan and port forwarding
I did get the new wdwebcamcapture program working with his web cam
i.e using the url like
http://[yourip]/cgi-bin/snapshot.cgi
and setting the user/pass
by also increasing the default time outs
and by setting to use async connection
try this new udpate
one thing though I am not sure if the picture updates after the first picture??
Not sure why but I am unable to run the new version of the exe.
I don’t know if it’s something on my end preventing me access or ???
See attached
what windows version?
Win10 Home
what about trying to run it as admin?
Gives me the same error…
is anyone else able to run it?
Hi Brian
I have a computer which I upgraded to win 10 pro from win 7 with a plan to replace one of the weather computers if they fail so is not used yet.
I have just installed wd on it but not run it, I then installed the reg and ini files off the computer doing the movies for my site and put the revised wdwebcamcapture program on, when I double clicked the wdwebcamcapture.exe it opened ok and had connected to my camera even though wd was not running. I also tried it on my win 10 home laptop without wd and it opened ok without any settings.
Hope this is of some help
Harold
Finally was able to run the webcam exe…will report how it goes once it has a chance to run for awhile…
