Hi all,
Does anyone know of a way to put the battery status values (WMR918/WMR968) on a web page?
TIA :lol:
Hi all,
TIA :lol:
Have you tried using the tags:
%wmr918/68tempbat3%…Battery status of the extra temp hum #3
%wmr918/68tempbat2%…Battery status of the extra temp hum #2
%wmr918/68tempbat1%…Battery status of the extra temp hum #1
%wmr918/68tempbat%…Battery status of the temp hum sensor
%wmr918/68consbat%…Battery status of the console
%wmr918/68rainbat%…Battery status of the rain gauge
%wmr918/68windbat%…Battery status of the wind sensor
output from WD would be:
100.0…Battery status of the extra temp hum #3
100.0…Battery status of the extra temp hum #2
100.0…Battery status of the extra temp hum #1
100.0…Battery status of the temp hum sensor
100.0…Battery status of the console
100.0…Battery status of the rain gauge
100.0…Battery status of the wind sensor
These can be built into an “wxlocal” that WD will update, then use that data for your screen.
Thanks. I will try that.
and if you tick you want to use custom tags in your web page under setup, webfiles/web page setup, you can add them to datahtm0.txt or datahtm3.txt
(i have not tested this though)
I got it going guys. I don
i see you are using the updated 9.96c, where i have reduced the width of the 5 day forecast image,and made the writting smaller…i think its an improvement, yes?
i see you are using the updated 9.96c, where i have reduced the width of the 5 day forecast image,and made the writting smaller....i think its an improvement, yes?It depends on how you look at it. :wink: It depends on your screen resolution. :lol: However, the text does not run together now. :)
Yes it is an improvement.
Thank you.
How is the fence mending coming along :?:
should be doing some today,although where I want to fix one its on asteep hill top, and its a cold wind today, but also am getting a new milk pump put in, and am keeping an eye on them…but at the same time trying to keep out of their way…and at the moment keep an eye on baby allister is still asleep while mum picks up the eldest from school and then cleans the local beach toilets for the local council…
