Hi, I changed my WMR200 rain gauge of increasing the diameter of the cup until to 300mm.
How do I set Weather Display?
Thanks Alberto
Thanks Alberto
you will need to change the modified rain gauge setting
in the units, rainfall setup
e.g if you increase the funnel size 2x, set the value there to 0.5
Note that the number refers to the increase in area, not diameter.
Thanks WINDY and NIKO, I had already tried to set the value to 0.5 but I get the impression that the readings are disproportionately more
Is there something I’m missing?.
What is the original diameter of the gauge?
You’ve tripled the diameter so you must enter 1/9, i.e. 0.1111 etc. (not sure how many dp are allowed).
The original diameter is 100mm.
Then this is correct:
Thanks guys for giving me lit !!!
The problem was calculated in relation to the whole surface of the funnel.
I wait for the next rain.
Alberto
