Following a reboot of my PC the datalogger starts up as normal to pull stored data from my WMR200 but it then seems to go on forever. I’ve stopped it after 20 minutes or so and WD finishes coming up.
The datalogger doesn’t seem to be pulling new (historical) data but is seeing new data when it arrives.
**Current actual data D2 2A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC 00
**data count 42 D2
**data count 16 D3
wind
raw wind data string D3 10 23 08 1A 03 0B 0D 0C 0C 20 01
Current speed= 1.2 m/s dir 292 average 1.8
**data count 16 D7
temp/hum
Current Channel # =1
Current temp =-4.6
Current hum =46
Live temperature/hum arrived
No more missed data count 1
**data count 42 D2
**data count 42 D2
**data count 42 D2
Any idea why it seems to be stuck in this loop?
I’ve attached my full wmr200history.txt file and wmr200d2data.txt file.
I haven’t tried it yet, and I’m new to ALL of this (new “sorta” hobby - As in the last month {I needed a new toy}), but if I recall the Windows software version of Weather Display software has a check box in the data download screen (near the bottom left) which when checked is supposed to clear the WMR200 flash memory after all the data is downloaded.
If it works as I am guessing it is supposed to, it should clear the data from the WMR200 and all your data will be in the Weather Display file.
Now - I could be wrong about this, so if there is someone here who can confirm this it would be appreciated.
It is my understanding that only the console can control WMR200 flash memory (i.e. the console will automatically try and down load historical data when connected to a computer rather than WD or any other program being able to ask for the data).
that clear the wmr200 setting is supposed to do the same as the console delete the data as posted by Skywright
but its only actioned after the data is all sent by the data logger anyway (and the data logger deletes the data from memory as its sent anyway (but sometimes there is ‘ghost’ data that is resent (i.e much older data), which is what might have happened
