Windows security update
Just a caution for the latest windows security update. After updating, it corrupted the weather display software. I had to rollback the changes.
No problems here with daily Win 10 Security Intelligence Updates: is that what you mean?
If you are sure, you should discuss this with Brian by e-mail.
no problems here with windows 11
I have win11. It was a security update for win 11. I’ve never had this issue before. Maybe just a one off thing. When I rolled the update back it was fine
so was that update KB5053598
windows does not do a graceful close of WD and if it happens at at data write time it can corrupt the data in WD most of the time there is not an issue but one or two on here have had it happen the ini and reg files in the backup folder then come into there own to get you back up and running
That makes sense. Never had an issue before. Live and learn
But you said you had to roll back the security update and then WD was fine. . . without using the backup ini and reg files?
The only thing I lost was Weather Underground Id and key. Everything else was fine
