Windows Problem
The problem I’m having with Windows shutting down WD is still around. Last night it happened at 2 AM. When I checked the the conputer in the morning I opened the WD screen the information is current but after moving the cursor over the screen the program locks and a short time later I get the Windows message saying it has expeirenced a problem with WD and will be shutting down. The WD programerrorlog.txt shows the first error at 2 AM (WD is set to upload to the web every 15 minutes). The web page shows the last update at 1:45 AM but the web cam image is current. The WD Live is still working and showing current data. All the other uploads are also current (CWOP, Anything Weather, Wunderground).
Here’s what’s in the programerrorlog:
Resetting rain daily value , day: 4
Resetting wind/temperature daily value , day: 4
ERROR: I/O error 32 at time/date 00:01:18 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 02:00:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 02:15:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 02:30:06 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 02:45:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 03:00:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 03:15:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 03:30:06 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 03:45:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 04:00:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 04:15:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 04:30:05 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 04:45:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 05:00:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 05:15:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 05:30:06 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 05:45:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 06:00:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 06:01:00 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 06:15:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 06:30:06 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 06:45:04 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 07:00:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 07:15:03 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 07:30:06 09/04/04
ERROR: Access violation at address 0041B0E8 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 07:45:03 09/04/04
This is an intermittent problem.
I too get an error every time I shut down WD using Win2k. This used to be a problem and was cured for a while but it seems to be back. It’s not much of a big deal though. I’ve been traveling alot so I haven’t shut WD down for the last couple of weeks.
