Wind speed isnt recording
Hiya
I have the Davis Vantage Vue, I am using WD v10.37q
I have noticed the wind speed or gust isnt being recorded to wd, nor the direction.
I have saved and exited the program and also restarted my pc, but still not joy!
I havn’t messed with any settings.
The Temperature, humidity and baro etc is fine.
Has anybody got any ideas as to what is causing this?
Cathy
http://www.widnes-weather.co.uk/
Is it showing anything on the console?
You could try rebooting that also.
Make sure connections are secure.
most likely you have a setting set wrong in WD
i.e you have WD set to use a 1 wire windspeed, vortex windspeed, or metar windspeed, or similar
best thing is to .zip and email me your settings files so I can check them
Ok thanks :slight_smile:
I am currently in work, I will send you the settings later in the day
@4wd yes the console is working ok.
I’ve only had my new station for 6 days now, so clearly I havn’t set something right :slight_smile:
hiya Brian
I’m not sure of which files to send to you?
http://discourse.weather-watch.com/t/12684
Thankyou :wink: files have been sent.
the problem is, you have set to use a the windspee/dir from a metar in the metar download in the ftp/internet setup
untick that setting
Thankyou very much for your help Brian :slight_smile:
Everything is working sound now, (didn’t even know that was ticked!)
Believe it or not, now we have no breeze tonight!! Typical!!
Cathy
