Wind Gust - jpgraph
Does anyone have a jpgraph php for wind gust for week, month, and/or year setup that they could share? I haven’t been able to find any and my coding capabilities are BAD :slight_smile:
See here for a set of graphs built from the clientraw files, something may suit your needs. You can find all about them here.
Thanks Stuart. I actually found and used some of these already. However, there are no "wind gust " charts for extended times only wind avg charts.
My starting point was to graph the data in the clientraw files (like WDL does). Unless you have a database or create the data some other way the information is not available to be graphed from a website. So you will need to create & upload the data you need in order to be able to create the graphs. I thought you might be able to use one or more of these graphs to use as a template.
Thanks Stuart. Is the gust data - hour, day, month, year etc published in a clientxxx file? I’m trying to figure out if i can create a graph using this data.
Here’s a clientraw parser:
http://www.tnetweather.com/wd-parser.php
Best Regards,
Martin
