Since I use WD the winddirection icon in the left part of the form does not change correct. The red indicator moves around but the yellow indicator always points north and has never moved.
I use Lacrosse 2310 with 2010 computer interface and WD 10.10L
has it awlays been the case with WD?
this i should be able to fix
Yes it has aways been pointing north, never moved one degree.
If you could fix it, I would be very happy.
ok, will have a look in the next few hours.
also, a new 10.10n should be better for the ws2010 data logger for the time hours on the graphs and the logging time interval too
Hello Brian,
Don’t know if you already looked at it, but the problem seems to appear when I choose Bft for unit. Now I use km/hr and suddenly the yellow indicator functions.
There are more problems when I use Bft. Maybe because that is not common unit for most people?
